[SOLVED]Child window: NOTIFICATION RELEASED
    • [SOLVED]Child window: NOTIFICATION RELEASED
      HI,
      I am working on Multiple windows and have problems being able to get it to function correctly. I hope someone here can guide me.
      1. I have two windows currently.
      2. Window 1- Parent window with a settings button.
      3. Pressing the settings button opens up child window.
      4. Window 2- Child window consists of three buttons.
      Question: I am pressing the button in child window, I don't understand how to control this? where will the control be passed to? Parent window? or the WM_NOTIFICATION_RELEASED in the child window? I have tried both of these and don't seem to understand what's going on.
      I have seen sample codes where there is only one button and reaction to the touch of the button changes the text on the button. Did not have any luck while I followed the same logic. I am also attaching the code I am currently working on.
      1. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
      2. extern void DrawBMPExternalMemory();
      3. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
      4. {
      5. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 320, 240, 0, 0x0, 0},
      6. { BUTTON_CreateIndirect, "Tools", GUI_ID_BUTTON5, 50, 193, 40, 40, 0, 0, 0 },
      7. };
      9. * Tools Callback
      10. **********************************************************************/
      11. static void _cbTools(WM_MESSAGE * pMsg)
      12. {
      13. switch (pMsg->MsgId)
      14. {
      15. case WM_PAINT:
      16. if(BUTTON_IsPressed(pMsg->hWin))
      17. {
      18. DrawBMPExternalMemory("GearDown.bmp");
      19. }
      20. else
      21. {
      22. DrawBMPExternalMemory("GearUp.bmp");
      23. }
      24. break;
      25. default:
      26. BUTTON_Callback(pMsg); // The original callback
      27. break;
      28. }
      29. }
      30. static void _cbCreateToolsScreen(WM_MESSAGE * pMsg)
      31. {
      32. BUTTON_Handle hButton1, hButton2, hButton3;
      33. int NCode;
      34. int Id;
      35. WM_HWIN hDlg;
      36. WM_PID_STATE_CHANGED_INFO * pInfo;
      37. hDlg = pMsg->hWin;
      38. switch (pMsg->MsgId)
      39. {
      40. case WM_CREATE:
      41. hButton1 = BUTTON_CreateEx(25, 50, 220, 45, WM_HBKWIN, WM_CF_SHOW, 0, GUI_ID_BUTTON8);
      42. BUTTON_SetText(hButton1, "O2 Cell calibration");
      43. hButton2 = BUTTON_CreateEx(25, 110, 220, 45, WM_HBKWIN, WM_CF_SHOW, 0, GUI_ID_BUTTON9);
      44. BUTTON_SetText(hButton2, "TouchScreen calibration");
      45. break;
      46. case WM_PAINT:
      47. //
      48. // Draw the background. This is quite important because otherwise we would still see the child window although it gets deleted.
      49. // With this drawing the background wouldn't "know" how to draw itself.
      50. //
      51. GUI_SetBkColor(GUI_BLACK);
      52. GUI_Clear();
      53. break;
      54. case WM_PID_STATE_CHANGED:
      55. Id = WM_GetId(pMsg->hWinSrc);
      56. NCode = pMsg->Data.v;
      57. switch (NCode)
      58. {
      59. pInfo = (WM_PID_STATE_CHANGED_INFO *)pMsg->Data.p;
      60. if (pInfo)
      61. {
      62. GUI_DispStringAt("Pressed", 10,10);
      63. if(Id == GUI_ID_BUTTON8)
      64. {
      65. GUI_SetBkColor(GUI_RED);
      66. }
      67. }
      68. }
      69. break;
      70. // USER START (Optionally insert additional message handling)
      71. // USER END
      72. default:
      73. WM_DefaultProc(pMsg);
      74. break;
      75. }
      76. }
      77. /*********************************************************************
      78. *
      79. * _cbDialog
      80. */
      81. static void _cbDialog(WM_MESSAGE * pMsg)
      82. {
      83. static WM_HWIN hWin;
      84. WM_HWIN hItem;
      85. int NCode;
      86. int Id;
      87. BUTTON_Handle hButton;
      88. TEXT_Handle hText1;
      89. TEXT_Handle hText2;
      90. hItem = pMsg -> hWin;
      91. switch (pMsg->MsgId)
      92. {
      93. case WM_INIT_DIALOG:
      94. WINDOW_SetBkColor(hItem, GUI_MAKE_COLOR(GUI_BEIGE_BACKGROUND));
      95. break;
      96. case WM_NOTIFY_PARENT:
      97. Id = WM_GetId(pMsg->hWinSrc);
      98. NCode = pMsg->Data.v;
      99. switch (NCode)
      100. {
      101. case WM_NOTIFICATION_RELEASED: // React only if released
      102. hItem = WM_GetDialogItem(pMsg->hWin, ID_WINDOW_0);
      103. if(Id == GUI_ID_BUTTON5)// ToolsScreen
      104. {
      105. hWin = WM_CreateWindowAsChild(0, 0, 320, 240, pMsg->hWin, WM_CF_SHOW, _cbCreateToolsScreen, 0);
      106. }
      107. }
      108. break;
      109. default:
      110. WM_DefaultProc(pMsg);
      111. }
      112. }
      113. /*********************************************************************
      114. *
      115. * Public code
      116. *
      117. **********************************************************************
      118. */
      119. /*********************************************************************
      120. *
      121. * MainTask
      122. */
      123. void BitmapOnButton(void)
      124. {
      125. //
      126. // Use memory devices for all windows
      127. //
      128. #if GUI_SUPPORT_MEMDEV
      129. WM_SetCreateFlags(WM_CF_MEMDEV);
      130. WM_EnableMemdev(WM_HBKWIN);
      131. #endif
      132. WM_SetDesktopColor(GUI_BLACK);
      133. while (1)
      134. {
      135. GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbDialog, 0, 0, 0);
      136. GUI_Delay(10);
      137. }
      138. }
      139. /*************************** End of file ****************************/
      Really appreciate any help at this point.
      BMD
      WM_NOTIFY_PARENT messages will always be sent to the widget's parent window. So if a button gets clicked, the WM_NOTIFY_PARENT message goes to the button's parent.
      You can then check the pMsg->Data.v value for the notification code. For example, if it is WM_NOTIFICATION_RELEASED, it means a click on that widget has been released.
      I've attached a simple example that demonstrates this, hopefully this will help you understand the mechanism better.
      Florian
    • Hi Florian,
      Thank you for the quick response.
      I am unable to see what's in the file you attached. It's a different extension I have never seen before. Could you please check and send it again.
      Best Regards,
      BMD
