EMBuild Option -D Questions
    • EMBuild Option -D Questions
      I am trying to do something similar to this post forum.segger.com/index.php/Thr…-SOLVED-EMBuild-D-option/ but I'm not having much luck.
      What I would like is to have a default version string defined so that a developer can build from the GUI or command line for development. When a release is going to be built then we will use the command line to build but I want to inject a specific version number during the command line build. How can I go about satisfying both requirements?
      Darren
    • Hello Darren,
      I am not sure what the issue is. Did you try what Johannes proposed in the other thread?
      You can set a default string via project macros for the GUI variant.
