Ozone + J-LINK Debugger attach to running program
    • Ozone + J-LINK Debugger attach to running program
      I am using Ozone 2.70a with a J-LINK Plus and am trying to attach the debugger to a running program without causing a reset. However, whenever I click the "Attach to running program" or "Attach and halt", the program jumps into the reset vector at 0x00000000. Does this always happen? Is there a way to prevent this from happening?
      Thanks!
      The post was edited 1 time, last by ucontrollerdude ().
      Default behaviour of our debug tools is that when a reset is issued a reset will be handled. If you do not want a target to be resetted you can overwrite the default reset behaviour in the Ozone script interface. How is explained in the Ozone manual UM08025.
    • What I am trying to do is use the "Attach to Running Program" (section 5.3.1.2 of UM08025) so I can attach the debugger to the program without causing a reset. It does not seem to be working for me because when I click this button, the PC jumps to 0x00000000. Section 5.3.1.2 states that phases 1 and 2 are executed so the reset phase is not executed (I confirmed that below). Going back to my original question, is it possible to connect to the target without the PC changing to 0x00000000?
      I am not issuing a reset. I added Util.Log messages in the following functions:
      TargetReset()
      BeforeTargetReset()
      AfterTargetReset()
      And the log message does not print out. When I do issue a reset the log statements print.
      I tried overwriting the AfterTargetConnect() function but setting the PC something outside the reset vector (like main() entry) gets me an undefined instruction exception. Guessing it's because the PC is changed abruptly while the program is still executing.
      What target device are you debugging exactly, some target devices can't be connected to without a reset due to their design.
      TargetReset()
      BeforeTargetReset()
      AfterTargetReset()
      Do you see the same behaviour with the latest Ozone version?
      To do this the target device must be halted first. So do a halt, change PC, go, then it should work as expected.
    • I am trying to target the RM46L852 (ti.com/product/RM46L852).
      I have not tested with the latest Ozone version, I will give that a shot.
      So I tried this:
      1. void AfterTargetConnect (void) {
      2. Debug.Halt();
      3. Target.SetReg("PC", 0x5654); // go to start of main
      4. Debug.Continue();
      5. }
      and I still get the undefined instruction exception. However, I also tried with just a "Debug.Halt()" in the above function, and the software PC is at 0x00000000 already so it is most likely the case that this microcontroller must be reset to connect to.
      Thank you for the help!
