Build example error
    • Build example error
      hi,
      windows7, SEGGER Embedded Studio for ARM Release 4.18 Build 2019070301.39449 Windows x64
      hardware:PCA10040
      After installing the software SES 4.18, open the example ble_app_uart_pca10040_s132,The building found:
      Building ‘ble_app_uart_pca10040_s132’ from solution ‘ble_app_uart_pca10040_s132’ in configuration ‘Debug’
      Assembling ‘thumb_crt0.s’
      Error starting process C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.18/gcc/arm-none-eabi/bin/cc1
      Build failed
      But the file cc1.exe can be found at C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.18/gcc/arm-none-eabi/bin/cc1.
      thank you !
      Such an issue is not known to us. Could you give the latest Embedded Studio version a try? Do you still see the same behaviour?
      Which Nordic SDK version are you using? Could you also use the latest version here?
