[SOLVED] J-link flashloader qspi 4 byte mode
  • [SOLVED] J-link flashloader qspi 4 byte mode
    I am using a STM32F769NI + micron MT25QL512 64MB memory which uses the ST_STM32F746G_Disco_QSPI.elf
    It works fine until I set the qspi to use 4 byte mode, after which it requires a power cycle to the board to connect.
    Is source available for this elf? Or is there some other workaround?
    Generally the flash loader provided by us works with the eval board with default configurationsIf you want to use another mode you will have to edit the flash loader.
    I sent you a PN with the link to the sources.
