Build Configuration
    • Build Configuration
      How do I set up a build configuration that is only valid for a specific project in a solution?
      I am creating a solution with 2 projects 'Project-A' and 'Project-B'. Both have 2 build configurations, 'Debug' and 'Release'.
      I set active project to 'Project-A' and create another public build configuration 'Build Test'.
      If I set active project to 'Project-B', I will still be offered build configuration 'Bild Test'. This build will fail.
      If I set active project to 'Project-A' or 'Project-B' and start Build Solution, SES tries to build 'Project-B' with build configuration 'Build Test'. This build will fail.
      Expected behavior:
      a) If I set active project to 'Project-A', build configuration (combo box) should offer 'Debug', 'Release' and 'Build Test'.
      b) If I set active project to 'Project-B', build configuration (combo box) should offer 'Debug', 'Release' and not 'Build Test'.
      c) If I start Build Solution, SES should build (a) and (b).
      How can I get the expected behavior?
      SES ARM V4.42 Linux 64bit
      How is your solution set up? Do you have any build dependencies set up?
      Could you provide an example project for reference?
