SCROLLBAR not always giving WM_NOTIFICATION_RELEASED
    • SCROLLBAR not always giving WM_NOTIFICATION_RELEASED
      I'm using a scrollbar to navigate in a larger text file. To avoid excessive CPU load when moving the thumb I want to notify only when the thumb is released (WM_NOTIFICATION_RELEASED). Now I noticed that sometimes the thumb is moved but no notification issued. Isn't it a precondition that the widget has to be clicked to change its value and then is released?
      Jan
      when the value of the SCROLLBAR changed, the notification code of the WM_NOTIFY_PARENT will be WM_NOTIFICATION_VALUE_CHANGED instead of WM_NOTIFICATION_RELEASED. This is intentional, since its value is what the widget is used for most of the times.
      For your purpose, I would just react on the WM_NOTIFICATION_VALUE_CHANGED code. This would make the most sense for scrolling through a text file. When the value changed, you can update your window accordingly, using the new scroll position.
      Florian
