I'm trying to flash an external flash (Norflash sst39vf3201C) with Jlink Plus and Jflash but it always return the same error:
- ERROR: Programming failed @ address 0x9000000 (item verification error)
I recently noticed that the Norflash fitted on the board is the SST39VF3201C, and not the one that I had selected in Jflash: SST39VF3201. However, SST39VF3201C is not supported by Jflash, at least it doesn't appear in the list of flashs.
Looking at the datasheet of this SST39VF3201C, the device's ID(BF235F) is different than the SST39VF3201 (BF235B). I tried to untick the option to check the manufacturer and device ID but the problem still there.
Is there any way to modify the manufacturer ID or add a new flash chip manually? would it be possible to add this version of the chip in future versions of the SW? The norflash I have fitted on my board should be the same as the one listed by Jflash as this one is just the new version of a chip that is on it's end end of life.
Let me know if you need more information. Thanks in advance
. Kind Regards
Álvaro.
Álvaro.
