[SOLVED] Ozone Data Sampling Change Counter becomes negative
  • [SOLVED] Ozone Data Sampling Change Counter becomes negative
    Ozone 3.10d here.
    when a debugging session with Data Sampling lasts a bit longer, the "# Changes" counter overruns and starts counting negative numbers towards 0.
    The reason is that the Changes field seems to have the same data type as the watched data itself. So for "short" it only counts up to 32k and then jumps to -32k.
    The post was edited 1 time, last by icwiener ().
    Good catch. Should be fixed with the next version.
