I'm unable to start a debugging session with Ozone.
Whenever I want to attach (no matter which way, downloading first or not). I get the following error;
I can also connect to the target using JLinkExe.
When I connect there I get the following back:
I can work with the same hardware combination on my windows PC with the same Ozone version without problem.
One thing I noticed, when I had the bootloader still flashed to the board (Adafruit Metro M0). I had the board go into bootloader mode whenever I tried to attach which suggests that Ozone triggers 2 consecutive resets because thats how the UF2 bootloader gets triggered to stay in bootloader.
Again this behaviour does not occur on Windows.
My system runs Ubuntu 18.04.4.
I'm able to flash to the board with openocd using the same JLink EDU (tried both classic and mini).Ozone wrote:
Debug.SetConnectMode (CM_ATTACH);
Debug.Start();
Device "ATSAMD21G18" selected.
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget(): PCode returned with error code -1
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
Connection failed.
JLinkExe wrote:
J-Link>connect
Connecting to target via SWD
InitTarget()
Found SW-DP with ID 0x0BC11477
DPIDR: 0x0BC11477
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0x41003000
CPUID register: 0x410CC601. Implementer code: 0x41 (ARM)
Found Cortex-M0 r0p1, Little endian.
FPUnit: 4 code (BP) slots and 0 literal slots
CoreSight components:
ROMTbl[0] @ 41003000
ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C0 ROM Table
ROMTbl[1] @ E00FF000
ROMTbl[1][0]: E000E000, CID: B105E00D, PID: 000BB008 SCS
ROMTbl[1][1]: E0001000, CID: B105E00D, PID: 000BB00A DWT
ROMTbl[1][2]: E0002000, CID: B105E00D, PID: 000BB00B FPB
ROMTbl[0][1]: 41006000, CID: B105900D, PID: 001BB932 MTB-M0+
Cortex-M0 identified.
