[SOLVED] [bug]SystemView V3.10, The terminal print API “SEGGER_SYSVIEW_ErrorfHost” cannot be resolved on the host side.
  • [SOLVED] [bug]SystemView V3.10, The terminal print API “SEGGER_SYSVIEW_ErrorfHost” cannot be resolved on the host side.
    1. SEGGER_SYSVIEW_ErrorfHost("log: CR1_write = %x", fpga_tx_format.data);
    1. The same target machine code is parsed normally in V2.52d.
    2. Under V3.10, the log level mark is not rendered, and the error log cannot be highlighted. And format output, parameter parsing is abnormal.
    3. “SEGGER_SYSVIEW_ErrorfTarget” is parsed normally, but the color rendering is not.
    • Figure 1, V2.52d is normal
    • Figure 2, V3.10 is abnormal
    There is an issue with the host formatter in SystemView.
    This will be fixed with the upcoming update, scheduled for this week.
    Sorry for any inconveniences caused.
