[SOLVED] System-view patch file doesn't support Cortex-M3 based MCUs
  • [SOLVED] System-view patch file doesn't support Cortex-M3 based MCUs
    I'm trying to use System View for FreeRTOS 9.0.0 running on Cortex-M3 based STM32F103 Micro. Noticed that the patch file is only for CM0 and CM4F based Micros and not for CM3. No change in patch file for for FreeRTOS v 10 either.
    Any reason Cortex-M3 was left out?
    The provided files are just samples for some popular platforms. If you need a CM3 variant you can use the CM4F sample and modify it to fit CM3.
    What is needed to instrument the code is explained in the SystemView manual.
