[SOLVED] How to setup SES solution options to connect to a remote JLink through a tunnel?
  • [SOLVED] How to setup SES solution options to connect to a remote JLink through a tunnel?
    "IP 012345678" or "IP tunnel:012345678" with JLink serial 012345678 does not seem to work.
    A how to is explained here:
    wiki.segger.com/Connect_to_rem…_via_J-Link_Tunnel_Server
    Are you following these exact steps?
    What Embedded Studio version are you using?
    What is the S/N of the J-Link you are using?
    Do you get any error messages?
    Are you using any firewalls in your network that might block traffic?
    Could you try the following in Embedded Studio?
    ip tunnel:682116514::jlink.segger.com
    Does this work?
    Good to hear that connection is working now.
    J-Link Remote Server has only a timeout if server replys take longer than 5 s. So if the ping between Client->Tunnel->Remote Server is more than 5 seconds it can come to timeouts but only after a initial connection is established.
  • Hi Nino,
    after some more testing I found there must be a timeout of 5 minutes somewhere when using the tunnel. This means: if a client does not connect to the remote server through the tunnel within 5 minutes after starting the remote server, the remote server needs to be restarted before a client can connect.
    Since I have access to the LAN through VPN, I would prefer to work without the tunnel. Unfortunately, this is not workable for me due to the issue described in:
    Stopping a debug session in one SES instance disconnects JLINK in other SES instance
    Can you have a look at that issue please?
