keil freezes and also RTT viewer couldnot establish connection with target
    • keil freezes and also RTT viewer couldnot establish connection with target
      I am working on ARM Cortex M4 development board provided by Vorago technologies. I am using keil IDE and connecting the target via J-link OB.
      At some instances of flashing the program/Entering into debug mode, the keil is becoming unresponsive.
      Currently "Run application at startup" is unchecked. Also under 'connect & reset options', connect is "Normal" , Reset is "Normal". Reset after connect is checked
      Also I have tried other 'connect & Reset options'
      Does this problem still occur with the latest version of the J-Link Software and Documentation Pack?
      You can download it here:
      segger.com/downloads/jlink/#J-…twareAndDocumentationPack
      NOTE:
      Please also update the J-Link DLL of Keil via the J-Link DLL Updater included in the Pack mentioned above.
      If the problem still persists after updating:
      1) Do you use custom hardware or an evaluation board? In the latter case which one?
      1.2) If custom hardware, do you experience the same problem on an evaluation board?
      2) Could you please send us a J-Link log file? How to enable:
    • Hi Fabian,
      I have updated the J-link software including DLL.
      But still the problem persists and after update the freezing of keil is happening more often compared to earlier version of J-link software
      1) I am using the evaluation board which is VA41630
      2) Find the attachments of J-link log file
      • JLinkARM.log
        (160 Byte, downloaded 5 times, last: )
      Did you set the RTT Viewer to use "existing session" + "auto reconnect"?
      If not, does it work when using RTT Viewer with these options enabled?
      Could you please provide us with a screenshot of the RTT Viewer's "Configuration" dialog?
    • New
      Hi Fabian,
      1) I did not set my connections to "existing session'' + "auto reconnect". refer to the below image for my current settings
      2) when I tried to use "existing session" + "auto reconnect", I am getting an error stating "J-link DLL did not send welcome string in time"
      3) Please check the attachment for the RTT viewer's log report when I connect with USB.
    • New
      we will be looking into this.
      I will come back to you as soon as we have news.
