[SOLVED] Ozone Watched Data with Default Refresh Rate?
    This can't be set globally, but on project level you can set it in your .jdebug file in OnProjectLoad as:
    Edit.SysVar (VAR_HSS_SPEED, FREQ_1_KHZ);
    This will be applied on each project launch for the data graph.
    Is this what you are looking for?
  • Hi Nino,
    thanks for your reply.
    What you describe acts on the Data Sampling and the Timeline views. What I mean is the Watched Data view. Variables entered there have a default refresh rate of Off which needs intervention for every singe variable added to see its value updated. ... Maybe there is a reason for doing it this way?
    Kind regards
    Yes sorry for confusion.
    To set the watch data refresh rate via .jdebug file you can use:
    Edit.RefreshRate ("VariableName", FREQ_1_HZ);
    The reason why everything defaults to off is that the watch window is a widely used feature for debugging even without the refresh functionally and only on Cortex-M targets you have the guarantee that you can access variables via runtime. This is not the case on other platforms that J-Link + Ozone support e.g. most Cortex-A targets so using another default than "Off" would introduce issues to a big portion of our customers if they would leave a default refresh value on that is not "Off" and we would like to avoid that.
