[SOLVED] Call OS_EnterInterrupt() inside IRQHandler throws an error
  • [SOLVED] Call OS_EnterInterrupt() inside IRQHandler throws an error
    I'm using EmbOS version: 5.06.1 on an IMXRT1062 board with a ARM Cortex M7.
    I'm writing my own driver for CANbus and I have defined some interrupt service routines that executes every time I send/receive a message.
    This is how I initialize the CAN and the IRQHandlers :
    /* Interrupt handlers. */
    extern "C" void CAN1_IRQHandler(void)
    MISRAC_DISABLE
    OS_EnterInterrupt();
    can1.interrupt_handler();
    OS_LeaveInterrupt();
    MISRAC_ENABLE
    extern "C" void CAN2_IRQHandler(void)
    MISRAC_DISABLE
    OS_VFP_Save();
    can2.interrupt_handler();
    OS_VFP_Restore();
    MISRAC_ENABLE
    * Init method for CAN
    void imx1062_can_t::init(uint32_t bitrate)
    OS_IncDI(); /*disable interrupts*/
    /* Init FlexCAN module. */
    FLEXCAN_GetDefaultConfig(&flexcanConfig);
    FLEXCAN_Init(this->can_ptr, &flexcanConfig, 40000000U);
    NVIC_SetPriority(CAN2_IRQn, 5u);
    NVIC_EnableIRQ(CAN2_IRQn);
    /* Setup RX message buffer to receive any ID */
    setupRxMessageBuffer(kFLEXCAN_FrameFormatStandard, kFLEXCAN_FrameTypeData);
    /* Set IMASK such that an interrupt is triggered on message receive in message buffer MESSAGE_OB_RX (community.nxp.com/thread/459431)*/
    this->can_ptr->IMASK1 = 1 << MESSAGE_OBJ_RX;
    OS_DecRI(); /*enable interrupts*/
    Since in the method interrupt_handler() I make some calls to OS functions (like OS_PutMail used for mailboxes) If I'm not mistaken I have to tell the OS that I'm within an interrupt, with the methods OS_EnterInterrupt() and OS_LeaveInterrupt().
    However, when OS_EnterInterrupt() gets executed, it throws a status error. I don't know where it is thrown because I cannot debug inside these methods.
    I saw some other threads in this community about my same problem, I tried to do what they tell to do:
    1) set the priority to a value higher then 127
    2) try to use the 'ARM' version of the methods to enable the interrupt
    //OS_ARM_InstallISRHandler(CAN2_IRQn, (OS_ISR_HANDLER*) CAN2_IRQHandler);
    //OS_ARM_ISRSetPrio(CAN2_IRQn, 130); // Set prio < 128
    //OS_ARM_EnableISR(CAN2_IRQn);
    But it didn't work.
    How can I fix it?
    thank you in advance,
    Giacomo
  • Dear Giacomo,
    Yes, that's correct.
    Which error code do you get? Most likely you are using an invalid interrupt priority.
    The iMXRT1062 has four interrupt priority bits implemented, thus NVIC_SetPriority() expects values from 0 to 15 and 0 is the highest priority.
    This is an invalid interrupt priority for embOS interrupts. Please try e.g. NVIC_SetPriority(CAN2_IRQn, 10u) instead.
    Please have a look here for more details: wiki.segger.com/Interrupt_prioritization
    Does that solve your issue? If not please let me know.
    Til
