ICONVIEW and External memory nOS
    • Florian,
      What I meant to say was the referred link has usage of code that are used for windows. Since I am not using any OS, I am not able to use some features so I modified it to fit my needs but it still doesn't seem to work. I have attached the code I am working on, could you please take a look at it and let me know what I am doing wrong?
      BMD
      2. * SEGGER Microcontroller GmbH *
      3. * Solutions for real time microcontroller applications *
      4. **********************************************************************
      5. * *
      6. * (c) 1996 - 2018 SEGGER Microcontroller GmbH *
      7. * *
      8. * Internet: www.segger.com Support: support@segger.com *
      9. * *
      10. **********************************************************************
      11. ** emWin V5.48 - Graphical user interface for embedded applications **
      12. emWin is protected by international copyright laws. Knowledge of the
      13. source code may not be used to write a similar product. This file may
      14. only be used in accordance with a license and should not be re-
      15. distributed in any way. We appreciate your understanding and fairness.
      16. ----------------------------------------------------------------------
      17. File : GUI_DrawExternalImage_BMP.c
      18. Purpose : Sample that shows how to draw external BMP images
      19. with emWin.
      20. This sample supports both usage in the Windows Simulation as well
      21. as usage on a target device using emFile.
      22. ---------------------------END-OF-HEADER------------------------------
      23. */
      24. #include "project.h"
      25. #include <stddef.h>
      26. #include <string.h>
      27. #include "WM.h"
      28. #include "BUTTON.h"
      29. #include "DIALOG.h"
      30. #include "Global Defines.h"
      31. #define GLOBALS_INTERNAL
      32. #include "Global Variables.h"
      33. #include "ICONVIEW.h"
      34. #include "GUI.h"
      35. #include "FS.h"
      36. /*********************************************************************
      37. *
      38. * Defines
      39. *
      40. **********************************************************************
      41. */
      42. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
      43. #define ID_ICONVIEW_0 (GUI_ID_USER + 0x01)
      44. #define ID_ICONVIEW_0_IMAGE_0 0x00
      45. /*********************************************************************
      46. *
      47. * Static data
      48. *
      49. **********************************************************************
      50. */
      51. /*********************************************************************
      52. *
      53. * _aDialogCreate
      54. */
      55. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
      56. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 320, 240, 0, 0x0, 0 },
      57. { ICONVIEW_CreateIndirect, "Iconview", ID_ICONVIEW_0, 10, 190, 50, 50, 0, 0x00320032, 0 },
      58. };
      59. /*********************************************************************
      60. *
      61. * Public code
      62. *
      63. **********************************************************************
      64. */
      65. /*********************************************************************
      66. *
      67. * _GetImageById
      68. */
      69. static const void * _GetImageById(U32 Id){
      70. const char * apImagePath[] = {
      71. // "\\AlarmAudio.bmp",
      72. // "\\AlarmNoSilenceIconDown.bmp",
      73. // "\\AlarmNoSilenceIconUp.bmp",
      74. // "\\ButtonBacklightUp.bmp"
      75. "\\Alarm&Audio.dta",
      76. "\\AlarmNoSilenceIconDown.dta",
      77. "\\AlarmNoSilenceIconUp.dta",
      78. "\\ButtonBacklightUp.dta"
      79. };
      80. if (Id < GUI_COUNTOF(apImagePath)) {
      81. return FS_FOpen(apImagePath[Id], "rb");
      82. } else {
      83. return 0;
      84. }
      85. }
      86. /*********************************************************************
      87. *
      88. * APP_GetData
      89. */
      90. int _GetDataBMP(void * p, const U8 ** ppData, unsigned NumBytes, U32 Off)
      91. {
      92. static U8 acBuffer[512];
      93. FS_FILE * pFile;
      94. int NumBytesRead;
      95. pFile = (FS_FILE *)p;
      96. //
      97. // Check buffer size
      98. //
      99. if (NumBytes > sizeof(acBuffer))
      100. {
      101. NumBytes = sizeof(acBuffer);
      102. }
      103. //
      104. // Set file pointer to the required position
      105. //
      106. FS_SetFilePos(pFile, Off, FS_FILE_BEGIN);
      107. //
      108. // Read data into buffer
      109. //
      110. NumBytesRead = FS_FRead(acBuffer, 1, NumBytes, pFile);
      111. //
      112. // Set data pointer to the beginning of the buffer
      113. //
      114. *ppData = (const U8 *)acBuffer;
      115. //
      116. // Return number of available bytes
      117. //
      118. return NumBytesRead;
      119. }
      120. /*********************************************************************
      121. *
      122. * _OwnerDraw
      123. */
      124. static int _OwnerDraw(const WIDGET_ITEM_DRAW_INFO * pDrawItemInfo) {
      125. const void * pData;
      126. switch (pDrawItemInfo->Cmd) {
      127. case WIDGET_ITEM_DRAW_BITMAP:
      128. pData = _GetImageById(pDrawItemInfo->ItemIndex);
      129. GUI_DrawStreamedBitmapExAuto(_GetDataBMP, (void *)&pData, pDrawItemInfo->x0, pDrawItemInfo->y0);
      130. return 0;
      131. default:
      132. return ICONVIEW_OwnerDraw(pDrawItemInfo);
      133. }
      134. }
      135. /*********************************************************************
      136. *
      137. * _cbDialog
      138. */
      139. static void _cbDialog(WM_MESSAGE * pMsg) {
      140. const void * pData;
      141. WM_HWIN hItem;
      142. U32 FileSize;
      143. int NCode;
      144. int Id;
      145. static GUI_BITMAP DummyBitmap;
      146. switch (pMsg->MsgId) {
      147. case WM_INIT_DIALOG:
      148. //
      149. // Initialization of 'Iconview'
      150. //
      151. hItem = WM_GetDialogItem(pMsg->hWin, ID_ICONVIEW_0);
      152. ICONVIEW_SetOwnerDraw(hItem, _OwnerDraw);
      153. // pData = _GetImageById("AlarmAudio.bmp", &FileSize);
      154. ICONVIEW_AddBitmapItem(hItem, &DummyBitmap, "");
      155. ICONVIEW_AddBitmapItem(hItem, &DummyBitmap, "Item");
      156. ICONVIEW_AddBitmapItem(hItem, &DummyBitmap, "Item");
      157. ICONVIEW_AddBitmapItem(hItem, &DummyBitmap, "Item");
      158. // ICONVIEW_AddStreamedBitmapItem(hItem, pData, "");
      159. // ICONVIEW_SetBkColor(hItem, ICONVIEW_CI_BK, GUI_MAKE_COLOR(0x00E1ECEE));
      160. break;
      161. case WM_NOTIFY_PARENT:
      162. Id = WM_GetId(pMsg->hWinSrc);
      163. NCode = pMsg->Data.v;
      164. switch(Id) {
      165. case ID_ICONVIEW_0: // Notifications sent by 'Iconview'
      166. switch(NCode) {
      167. case WM_NOTIFICATION_CLICKED:
      168. break;
      169. case WM_NOTIFICATION_RELEASED:
      170. break;
      171. case WM_NOTIFICATION_MOVED_OUT:
      172. break;
      173. case WM_NOTIFICATION_SCROLL_CHANGED:
      174. break;
      175. case WM_NOTIFICATION_SEL_CHANGED:
      176. break;
      177. }
      178. break;
      179. }
      180. break;
      181. default:
      182. WM_DefaultProc(pMsg);
      183. break;
      184. }
      185. }
      186. /*********************************************************************
      187. *
      188. * Public code
      189. *
      190. **********************************************************************
      191. */
      192. /*********************************************************************
      193. *
      194. * MainTask
      195. */
      196. void BitmapOnIconview(void) {
      197. FS_Init();
      198. GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
      199. while (1) {
      200. GUI_Delay(100);
      201. }
      202. }
      I was able to make the modifications but I am not able to set the index to display different icons. Could you please see the code and tell me how to do that so I am able to display all the Icons as required?
      2. */
      3. #include "project.h"
      4. #include <string.h>
      5. #include "WIDGET.h"
      6. #include "WM.h"
      7. #include "BUTTON.h"
      8. #include "DIALOG.h"
      9. #include "ICONVIEW.h"
      10. #include "FS.h"
      11. /*********************************************************************
      12. *
      13. * Defines
      14. *
      15. **********************************************************************
      16. */
      17. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
      18. #define ID_ICONVIEW_0 (GUI_ID_USER + 0x01)
      19. #define ID_ICONVIEW_1 (GUI_ID_USER + 0x02)
      20. #define ID_TEXT_0 (GUI_ID_USER + 0x03)
      21. #define ID_ICONVIEW_0_IMAGE_0 0x01
      22. #define ID_ICONVIEW_1_IMAGE_0 0x02
      23. #define RECOMMENDED_MEMORY (1024L * 5)
      24. int touch = 0;
      25. /*********************************************************************
      26. *
      27. * Static data
      28. *
      29. **********************************************************************
      30. */
      31. /*********************************************************************
      32. *
      33. * _aDialogCreate
      34. */
      35. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
      36. {
      37. { WINDOW_CreateIndirect, "Window", 0, 0, 0, 320, 240},
      38. { ICONVIEW_CreateIndirect, "UpArrow", ID_ICONVIEW_0, 35, 10, 30, 44},
      39. { TEXT_CreateIndirect, "AlarmNoSilenceTimer", ID_TEXT_0, 10, 40, 30, 20, 0, 0x64, 0 },
      40. { ICONVIEW_CreateIndirect, "DownArrow", ID_ICONVIEW_1, 35, 50, 30, 44},
      41. };
      42. /*********************************************************************
      43. *
      44. * Public code
      45. *
      46. **********************************************************************
      47. */
      48. unsigned int UpArrowLeft = 21;
      49. unsigned int UpArrowRight;
      50. unsigned int DownArrowLeft;
      51. unsigned int DownArrowRight = 100;
      52. /*********************************************************************
      53. *
      54. * _GetImageById
      55. */
      56. static const void * _GetImageById(U32 Id)
      57. {
      58. FS_FILE * pFile;
      59. char acVolumeName[10];
      60. const char * apImagePath[] =
      61. {
      62. "UpArrow.bmp",
      63. "GearUp.bmp",
      64. "O2Cell.bmp",
      65. };
      66. if (Id < GUI_COUNTOF(apImagePath))
      67. {
      68. FS_GetVolumeName(0, acVolumeName, sizeof(acVolumeName));
      69. if (FS_Mount(acVolumeName) > 0)
      70. {
      71. pFile = FS_FOpen(apImagePath[Id], "rb");
      72. }
      73. return pFile;
      74. }
      75. else
      76. {
      77. return 0;
      78. }
      79. }
      80. /*********************************************************************
      81. *
      82. * APP_GetData
      83. */
      84. int _GetDataBMP(void * p, const U8 ** ppData, unsigned NumBytes, U32 Off)
      85. {
      86. static U8 acBuffer[512];
      87. FS_FILE * pFile;
      88. int NumBytesRead;
      89. pFile = (FS_FILE *)p;
      90. //
      91. // Check buffer size
      92. //
      93. if (NumBytes > sizeof(acBuffer))
      94. {
      95. NumBytes = sizeof(acBuffer);
      96. }
      97. //
      98. // Set file pointer to the required position
      99. //
      100. FS_SetFilePos(pFile, Off, FS_FILE_BEGIN);
      101. //
      102. // Read data into buffer
      103. //
      104. NumBytesRead = FS_FRead(acBuffer, 1, NumBytes, pFile);
      105. //
      106. // Set data pointer to the beginning of the buffer
      107. //
      108. *ppData = (const U8 *)acBuffer;
      109. //
      110. // Return number of available bytes
      111. //
      112. return NumBytesRead;
      113. }
      114. /*********************************************************************
      115. *
      116. * _OwnerDraw
      117. */
      118. static int _OwnerDraw(const WIDGET_ITEM_DRAW_INFO * pDrawItemInfo)
      119. {
      120. FS_FILE *pFile;
      121. switch (pDrawItemInfo->Cmd)
      122. {
      123. case WIDGET_ITEM_DRAW_BITMAP:
      124. pFile = _GetImageById(pDrawItemInfo->ItemIndex);
      125. GUI_BMP_DrawEx(_GetDataBMP, pFile, pDrawItemInfo->x0,pDrawItemInfo->y0);
      126. FS_FClose(pFile);
      127. return 0;
      128. default:
      129. return ICONVIEW_OwnerDraw(pDrawItemInfo);
      130. }
      131. }
      132. /*********************************************************************
      133. *
      134. * _cbDialog
      135. */
      136. static void _cbDialog(WM_MESSAGE * pMsg)
      137. {
      138. WM_HWIN hItem;
      139. int NCode;
      140. int Id;
      141. // BUTTON_Handle hButton;
      142. // ICONVIEW_Handle hIcon;
      143. TEXT_Handle hText1;
      144. GUI_BITMAP DummyBitmap;
      145. switch (pMsg->MsgId)
      146. {
      147. case WM_PAINT:
      148. GUI_SetBkColor(0x00E1ECEE);
      149. GUI_SetColor(0x00DBA47B);
      150. GUI_SetPenSize(1);
      151. GUI_DrawLine(0,188, 320,188);
      152. GUI_DrawRect(175,190, 316,238);
      153. GUI_DrawLine(247, 190, 247, 237);
      154. GUI_SetColor(0x00774409);
      155. GUI_SetPenSize(3);
      156. GUI_DrawLine(5, 167, 105, 167);
      157. GUI_DrawLine(210, 167, 320, 167);
      158. GUI_SetFont(GUI_FONT_24B_1);
      159. GUI_SetColor(0x00774409);
      160. GUI_DispStringAt("21",10,139);
      161. GUI_DispStringAt("100",282,139);
      162. GUI_DispDecAt(DownArrowRight, 282, 40, 3);
      163. break;
      164. case WM_INIT_DIALOG:
      165. WINDOW_SetBkColor(hItem, GUI_MAKE_COLOR(0x00E1ECEE));
      166. //
      167. // Initialization of 'Iconview'
      168. //
      169. // pDrawItemInfo->ItemIndex = 0;
      170. hItem = WM_GetDialogItem(pMsg->hWin, ID_ICONVIEW_0);
      171. ICONVIEW_SetOwnerDraw(hItem, _OwnerDraw);
      172. ICONVIEW_AddBitmapItem(hItem, &DummyBitmap, "");
      173. //ICONVIEW_AddBitmapItem(hItem, _GetImageById(0), "");
      174. // ICONVIEW_SetBkColor(hItem, ICONVIEW_CI_BK, GUI_MAKE_COLOR(0x00E1ECEE));
      175. //
      176. // Initialization of 'AlarmNoSilenceTimer'
      177. //
      178. hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
      179. TEXT_SetFont(hItem, GUI_FONT_24B_1);
      180. TEXT_SetText(hItem, "21");
      181. hItem = WM_GetDialogItem(pMsg->hWin, ID_ICONVIEW_1);
      182. ICONVIEW_SetOwnerDraw(hItem, _OwnerDraw);
      183. ICONVIEW_AddBitmapItem(hItem, &DummyBitmap, "");
      184. //ICONVIEW_AddBitmapItem(hItem, _GetImageById(1), "");
      185. break;
      186. case WM_NOTIFY_PARENT:
      187. Id = WM_GetId(pMsg->hWinSrc);
      188. NCode = pMsg->Data.v;
      189. switch (NCode)
      190. {
      191. case WM_NOTIFICATION_RELEASED: // React only if released
      192. hText1 = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
      193. if(Id == ID_ICONVIEW_0)
      194. {
      195. GUI_ClearRect(10,10,38,65);
      196. UpArrowLeft = (UpArrowLeft+1);
      197. TEXT_SetDec (hText1,UpArrowLeft,2,0,0,1);
      198. }
      199. if(Id == GUI_ID_BUTTON0)
      200. {
      201. }
      202. break;
      203. }
      204. break;
      205. default:
      206. WM_DefaultProc(pMsg);
      207. }
      208. }
      209. /*********************************************************************
      210. *
      211. * Public code
      212. *
      213. **********************************************************************
      214. */
      215. /*********************************************************************
      216. *
      217. * MainTask
      218. */
      219. void BitmapOnIconview(void)
      220. {
      221. //
      222. // Check if recommended memory for the sample is available
      223. //
      224. if (GUI_ALLOC_GetNumFreeBytes() < RECOMMENDED_MEMORY)
      225. {
      226. GUI_ErrorOut("Not enough memory available.");
      227. return;
      228. }
      229. //
      230. // Use memory devices for all windows
      231. //
      232. #if GUI_SUPPORT_MEMDEV
      233. WM_SetCreateFlags(WM_CF_MEMDEV);
      234. WM_EnableMemdev(WM_HBKWIN);
      235. #endif
      236. WM_SetDesktopColor(GUI_BLACK);
      237. while (1)
      238. {
      239. GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbDialog, 0, 0, 0);
      240. GUI_Delay(10);
      241. }
      242. }
      243. /*************************** End of file ****************************/
      Appreciate all the help!
      Thanks and regards,
      BMD
    • Florian/Sven,
      Could you please help me understand how to display different images assigned to different icons from external memory?? So far, I can only see same image on all the icons. I couldn't find anything on the forum regarding this as well. Any hint will be greatly appreciated.
      Thanks and regards,
      BMD
