[SOLVED] How to set VAR_BREAK_AT_THIS_SYMBOL in the jdebug
  • [SOLVED] How to set VAR_BREAK_AT_THIS_SYMBOL in the jdebug
    I have the same basic question as found in this thread:
    forum.segger.com/index.php/Thr…S-SYMBOL-value-by-script/
    How should I set VAR_BREAK_AT_THIS_SYMBOL in the jdebug project file?
    When I have started up the debugging process, the following works in the console.
    Edit.SysVar (VAR_BREAK_AT_THIS_SYMBOL, main_dev);
    The old jlink script spec says that the type of the symbol should be an integer.
    I have tried setting the variable with hopes that it would be overwritten.
    unsigned int main_dev = 0;
    Then I get:
    String argument expected in command "EditSysVar": 0x0 (0)
    I would really appreciate better documentation :). There is not a string type specified anywhere.
    When define the variable as requested, I get the following.
    char* main_dev = "main_dev";
    Error (77): Script interpretation failure: expected a base type at line 23, column 27.
    The base types as documented include 'char'.
    Please instruct me on how to set VAR_BREAK_AT_THIS_SYMBOL in the jdebug-file.
    Thank you for the help!
    Which Ozone version are you currently using?
    In Ozone V3.10c there was a fix related to the break symbol.
    Could you give V3.10c a try and see if the behaviour improves?
    Your approach is correct. It appears that the bug in Ozone was not fixed for all cases. This should be the case with the next Ozone release V3.10d.
    To stay up to date with Ozone releases you can subscribe here:
    segger.com/notification/subscribe.php?prodid=178,7
  • Hello Brian,
