[CLOSED] STM32G431CB / Flash issue
  • [CLOSED] STM32G431CB / Flash issue
    I am using J-Flash V6.60f to flash a STM32G431CB (SWD interface) with a given .hex file.
    Everything goes well until "Restoring" (message at the end of the message):
    Start of restoring
    - ERROR: Timeout while restoring target, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x21000000)!
    - ERROR: Failed to restore target. RAMCode never stops
    - End of restoring
    What does this step exactly?
    How can I get rid of this issue?
    Thanks forward for your help,
    Kind regards,
    Sébastien
    Programming and verifying target (12968 bytes, 2 ranges) ...
    - Checking if selected data fits into selected flash sectors.
    - Start of preparing flash programming
    - End of preparing flash programming
    - Start of determining dirty areas in flash cache
    - End of determining dirty areas
    - CPU is running at 56000 kHz.
    - Start of flash programming
    - Programming range 0x08000000 - 0x080037FF ( 7 Sectors, 14 KB)
    - End of flash programming
    - Flash programming performed for 1 range (14336 bytes)
    - 0x8000000 - 0x80037FF ( 7 Sectors, 14 KB)
    - Start of verifying flash
    - End of verifying flash
    - Start of restoring
    - End of restoring
    - ERROR: Failed to program and verify target
    Disconnecting ...
    - Disconnected
  • Hi Sébastien,
    We are analyzing an issue regarding the STM32G431-series right now.
    What you are experiencing seems to be connected to this issue.
    We will come back to you as soon as we have news about this.
