[ABANDONED] JLINK Unspecified Error -1
  • [ABANDONED] JLINK Unspecified Error -1
    I'm getting the following error after flashing from a commander script Unspecified error -1 and was wondering if there is an issue with my commander script?
    When I keep re-running the commander script I always get the same error, until I open up MCUxpresso and running it from the play button there.
    Here is my commanderscript:
    1. device LPC54102J256_M4
    2. si 1
    3. speed 2000
    4. erase
    5. loadfile test.hex
    6. sleep 100
    7. r
    8. g
    9. exit
    and here is the full output error log:
    1. SEGGER J-Link Commander V6.56b (Compiled Dec 6 2019 15:02:40)
    2. DLL version V6.56b, compiled Dec 6 2019 15:02:24
    3. J-Link Command File read successfully.
    4. Processing script file...
    5. J-Link connection not established yet but required for command.
    6. Connecting to J-Link via USB...O.K.
    7. Firmware: J-Link V10 compiled Nov 8 2019 16:40:12
    8. Hardware version: V10.10
    9. S/N: 50109947
    10. License(s): GDB
    11. VTref=3.341V
    12. Selecting SWD as current target interface.
    13. Selecting 2000 kHz as target interface speed
    14. Target connection not established yet but required for command.
    15. Device "LPC54102J256_M4" selected.
    16. Connecting to target via SWD
    17. Found SW-DP with ID 0x2BA01477
    18. Scanning AP map to find all available APs
    19. AP[1]: Stopped AP scan as end of AP map has been reached
    20. AP[0]: AHB-AP (IDR: 0x24770011)
    21. Iterating through AP map to find AHB-AP to use
    22. AP[0]: Core found
    23. AP[0]: AHB-AP ROM base: 0xE00FF000
    24. CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    25. Found Cortex-M4 r0p1, Little endian.
    26. FPUnit: 6 code (BP) slots and 2 literal slots
    27. CoreSight components:
    28. ROMTbl[0] @ E00FF000
    29. ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    30. ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    31. ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    32. ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    33. ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    34. ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    35. Cortex-M4 identified.
    36. Erasing device...
    37. Comparing flash [000%]100%] Done.
    38. Erasing flash [000%]000%]010%]010%]025%]025%]035%]035%]050%]050%]060%]060%]075%]075%]085%]085%]100%] Done.
    39. J-Link: Flash download: Total time needed: 0.956s (Prepare: 0.062s, Compare: 0.000s, Erase: 0.890s, Program: 0.000s, Verify: 0.000s, Restore: 0.004s)
    40. Erasing done.
    41. Downloading file [test.hex]...
    42. Comparing flash [000%]000%]040%]040%]050%]100%] Done.
    43. Erasing flash [000%]100%] Done.
    44. Programming flash [000%]000%]000%]000%]000%]000%]000%]000%]005%]005%]005%]005%]005%]005%]005%]005%]010%]010%]010%]010%]010%]010%]010%]010%]015%]015%]015%]015%]015%]015%]015%]015%]020%]020%]020%]020%]020%]020%]020%]020%]025%]025%]025%]025%]025%]025%]025%]025%]030%]030%]030%]030%]030%]030%]030%]030%]035%]035%]035%]035%]035%]035%]035%]035%]040%]040%]040%]040%]040%]040%]040%]040%]045%]045%]045%]045%]045%]045%]045%]045%]050%]050%]050%]050%]050%]050%]050%]050%]055%]055%]055%]055%]055%]055%]055%]055%]060%]060%]060%]060%]060%]060%]060%]060%]065%]065%]065%]065%]065%]065%]065%]065%]070%]070%]070%]070%]070%]070%]070%]070%]075%]075%]075%]075%]075%]075%]075%]075%]080%]080%]080%]080%]080%]080%]080%]080%]085%]085%]085%]085%]085%]085%]085%]085%]090%]090%]090%]090%]090%]090%]090%]090%]095%]095%]095%]095%]095%]100%] Done.
    45. Verifying flash [000%]000%]080%]080%]100%] Done.
    46. J-Link: Flash download: Bank 0 @ 0x00000000: 1 range affected (163840 bytes)
    47. J-Link: Flash download: Total time needed: 1.266s (Prepare: 0.097s, Compare: 0.022s, Erase: 0.000s, Program: 1.090s, Verify: 0.014s, Restore: 0.042s)
    48. Unspecified error -1
    49. Reset delay: 0 ms
    50. Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
    51. Reset: Halt core after reset via DEMCR.VC_CORERESET.
    52. Reset: Reset device via AIRCR.SYSRESETREQ.
    53. Script processing completed.
    Any ideas of what I am doing wrong would be greatly appreciated!
    Thanks in advance
    Does this behavior also appear when using the newest J-Link Software and Documentation Pack version?
    You can download it here:
    If so, could you please verify if the target was successfully programmed and running after executing the script?
