J-Flash - Failed to erase chip
    • J-Flash - Failed to erase chip
      I am using J-Link Pro on an STM32F412 and I am trying to erase the chip with J-Flash.
      If I select Target -> Manual Programming -> Erase Chip, I get a pop-up dialog doing some work and then an error message pop-up telling me, erasing had failed. The log says:
      Erasing chip ...
      - 264 sectors, 2 ranges, 0x8000000 - 0x807FFFF, 0x90000000 - 0x90FFFFFF
      - Start of preparing flash programming
      - End of preparing flash programming
      - Start of determining dirty areas in flash cache
      - End of determining dirty areas
      - CPU is running at 72000 kHz.
      - Chip erase not supported for flash bank @ 0x08000000. Switched to sector erase
      - Start of erasing sectors
      - Blank checking 0x08000000 - 0x0800FFFF
      - Erasing range 0x08000000 - 0x0800FFFF ( 4 Sectors, 64 KB)
      - Blank checking 0x08010000 - 0x0801FFFF
      - Erasing range 0x08010000 - 0x0801FFFF ( 1 Sector, 64 KB)
      - Blank checking 0x08020000 - 0x0803FFFF
      - Erasing range 0x08020000 - 0x0803FFFF ( 1 Sector, 128 KB)
      - Blank checking 0x08040000 - 0x0805FFFF
      - Blank checking 0x08060000 - 0x0807FFFF
      - End of erasing sectors
      - Start of restoring
      - End of restoring
      - Start of determining flash info (Bank 1 @ 0x90000000)
      - End of determining flash info
      - Flash bank info:
      - 256 * 64 KB @ 0x90000000
      - CPU speed could not be measured.
      - Chip erase not supported for flash bank @ 0x90000000. Switched to sector erase
      - Erasing range 0x90000000 - 0x9001FFFF ( 2 Sectors, 128 KB)
      - ERROR: Failed to erase sectors.
      - ERROR: Erase failed
      - End of restoring
      - ERROR: Failed to erase chip
      However, Target -> Manual Programming -> Download & Verify works just fine.
      Any idea what is going on?
      Thanks.
      Kind regards
      Do you use custom hardware or an evaluation board? In the latter case which one?
      If custom hardware, do you experience the same problem on an evaluation board?
      Could you please erase the target via J-Link Commander and tell us if it works?:
      - Open the J-Link commander
      - Connect to the target
      - Write "erase" to erase the device (without quotations)
      thanks for your answer.
      It is a custom board. I do not have an eval board at hand. I can test with one over the week end and will add the results here then.
      In J-Link Commander (connected via SWD), erasing finished successfully.
      J-Link>connect
      Please specify device / core. <Default>: STM32F412CE
      Type '?' for selection dialog
      Device>
      J) JTAG (Default)
      S) SWD
      T) cJTAG
      TIF>s
      Speed>
      Device "STM32F412CE" selected.
      Connecting to target via SWD
      AP[0]: Core found
      CoreSight components:
      ROMTbl[0] @ E00FF000
      ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
      ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
      ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
      ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
      Cortex-M4 identified.
      J-Link>erase
      Erasing device...
      J-Link: Flash download: Only internal flash banks will be erased.
      To enable erasing of other flash banks like QSPI or CFI, it needs to be enabled via "exec EnableEraseAllFlashBanks"
      J-Link: Flash download: Total time needed: 7.986s (Prepare: 0.024s, Compare: 0.000s, Erase: 7.958s, Program: 0.000s, Verify: 0.000s, Restore: 0.004s)
      Erasing done.
      The J-Link log file is attached.
      /Edit: I connected the J-Link to an STM32F103C8 (blue pill) today and it can be erased just fine with Commander and J-Flash.
      Thanks and regards.
      • JLinkARM.log
        (30.49 kB, downloaded 15 times, last: )
      The post was edited 1 time, last by icwiener ().
      Does erasing with the J-Link Commander work when using the command "exec EnableEraseAllFlashBanks" (w.o. quotations)?
      After erasing the target with the J-Link Commander, does the problem still persist with J-Flash?
      thanks for your suggestion.
      EDIT: Sorry, this seems to be an unrelated issue. I will update this post once I have new information.
      EDIT2: I just tried it again and the error is still as shown below.
      erase failes here after issuing that command. Here is the output.
      SEGGER J-Link Commander V6.62 (Compiled Jan 24 2020 16:32:43)
      DLL version V6.62, compiled Jan 24 2020 16:32:09
      Firmware: J-Link Pro V4 compiled Jan 7 2020 16:52:59
      Hardware version: V4.00
      S/N: 174505828
      IP-Addr: DHCP (no addr. received yet)
      VTref=3.332V
      J-Link>connect
      Device>
      J) JTAG (Default)
      S) SWD
      T) cJTAG
      TIF>s
      Speed>
      DPIDR: 0x2BA01477
      AP[0]: Core found
      J-Link>exec EnableEraseAllFlashBanks
      J-Link>erase
      Erasing device...
      ****** Error: Failed to prepare for programming.
      RAM check failed @ addr 0x200012F8.
      RAM check failed while testing 0x2050 bytes @ addr 0x200006CC.
      ERROR: Erase returned with error code -1.
      The post was edited 2 times, last by icwiener ().
      Do you have any peripheral flash connected to the chip at address 0x90000000?
      Could you please check, that there are no flash banks enabled in the J-Flash project, that are not accessible?
      You can do so here:
