Processor frezzes after Enabled the Interrupt source
    • Processor frezzes after Enabled the Interrupt source
      I moved project from Keil to Segger Embedded studio and now while i debugging my processor freezes after enabled the interrupt sources.
      When i used keil the whole program worked correctly. What can i do to make debug work correctly at Segger?
      I flash via j-link and use STM32F103VC
      First, I imported using the internal toolchain. When building, I got 2 errors:
      1. 1> error: undefined symbol: __RESETPRIMASK
      2. 1> error: undefined symbol: __SETPRIMASK
      and want to change the following functions:
      1. /*******************************************************************************
      2. * Function Name : NVIC_SETPRIMASK
      3. * Description : Enables the PRIMASK priority: Raises the execution priority to 0.
      4. * Input : None
      5. * Output : None
      6. * Return : None
      7. *******************************************************************************/
      8. void NVIC_SETPRIMASK(void)
      9. {
      10. __SETPRIMASK();
      11. }
      12. /*******************************************************************************
      13. * Function Name : NVIC_RESETPRIMASK
      14. * Description : Disables the PRIMASK priority.
      15. * Input : None
      16. * Output : None
      17. * Return : None
      18. *******************************************************************************/
      19. void NVIC_RESETPRIMASK(void)
      20. {
      21. __RESETPRIMASK();
      22. }
      I have tried to use assembler instructions that replicate the functions but with no avail.
      Does anyone have a similar experience?
      The post was edited 2 times, last by Akatosh ().
