[SOLVED] Feature Request RTT: SEGGER_RTT_Peek()
  • [SOLVED] Feature Request RTT: SEGGER_RTT_Peek()
    Hi!
    I'm using RTT on an Arduino platform, replacing a default Serial output to instead use RTT on user request.
    One of the capabilities required by the existing Arduino Stream class (which Serial must support) is a Peek function to obtain the next character of down data, if one is available.
    Would it be possible to add a SEGGER_RTT_Peek() [always for terminal] or SEGGER_RTT_Peek(bufferIndex) function?
    Here's a draft diff based on RTT version 6.60d ($Rev: 16714 $):
    github.com/henrygab/Adafruit_n…11dac11c929c762040f238d12
    Thank you for considering this simple proposal.
    Henry
  • New
    Hi Henry,
    Thank you for your feature suggestion.
    I will forward this to the corresponding department and we will discuss this internally.
