Two suggestions! Separate color on MULTIPAGE Tabs, Text Label on BUTTON pressed
    • Hi Amir,
      thank you for your suggestions, we will consider adding them to emWin. Although, both of this can already be achieved with emWin using skinning.
      Several text labels for a button are pretty easy to do, you need to set a skinning routine that displays the texts based on BUTTON_IsPressed() in the WIDGET_ITEM_DRAW_TEXT case.
      A custom color for each MULTIPAGE tab can be done similarly, by setting a skinning routine. When the background is drawn in the WIDGET_ITEM_DRAW_BACKGROUND case, the user can pick a color according to the tab index. The tab index can be read from pDrawItemInfo->ItemIndex.
      If you want to have actual samples to learn how to do this, please let me know.
      Florian
