Button transparency
    • Button transparency
      I wanted to set transparent background for button widget. I have done this using following implementation but when I enable BUTTON_SetSkinFlexProps() then it took ~20 seconds to load the screen.
      When I comment out following code then the screen loads smoothly without delay.
      I have tried BUTTON_SetBkColor() function to set the background color but it has no effect on the button's background color.
      Could you please help me to set the background for button widget?
      typedef struct {
      GUI_COLOR aColorFrame[3];
      GUI_COLOR aColorUpper[2];
      GUI_COLOR aColorLower[2];
      int Radius;
      } BUTTON_SKINFLEX_PROPS;
      BUTTON_SKINFLEX_PROPS props;
      props.aColorFrame[0] = 0x373737;
      props.aColorFrame[1] = 0x373737;
      props.aColorFrame[2] = 0x373737;
      props.aColorLower[0] = 0x373737;
      props.aColorLower[1] = 0x373737;
      props.aColorLower[2] = 0x373737;
      props.aColorUpper[0] = 0x373737;
      props.aColorUpper[1] = 0x373737;
      props.aColorUpper[2] = 0x373737;
      BUTTON_SetSkinFlexProps(&props, BUTTON_SKINFLEX_PI_ENABLED);
      BUTTON_SetSkinFlexProps(&props, BUTTON_SKINFLEX_PI_PRESSED);
      BUTTON_SetSkinFlexProps(&props, BUTTON_SKINFLEX_PI_FOCUSSED);
      BUTTON_SetSkinFlexProps(&props, BUTTON_SKINFLEX_PI_DISABLED);
      Vikram
      BUTTON_SetBkColor() only works when not using skinning. The best way to display a button transparent would be to set a callback routine and do nothing, since the button is already a transparent window.
      What exactly do you mean by transparent background?
      Thanks and best regards,
      Florian
