[SOLVED] Can't get SystemView to run correctly
  • [SOLVED] Can't get SystemView to run correctly
    Hello *,
    I want to use SystemView on my STM32F407ZG with FreeRtos. By now I´ve tried two ways with different success:
    1.:
    Using CubeMX only for startup-code
    Using a patched Freertos 10.2.1
    Adding the code for the configassert problem
    Adding the defines from the wiki
    No CMSIS-OS calls
    I can see no tasks exept Systick and Idle, but the tasks are running (LEDs are blinking)
    1.:
    Using CubeMX incl. activated Freertos incl. 4 empty tasks
    Replacing the RTOS-files with the patched Freertos 10.2.1 from above
    I can see the tasks but the controller runs in a hard fault
    Any ideas? My favorit solution for implementing Freertos would be the first because I´m independent from ST regarding
    the version of Freertos.
