[Solved] Programming the MCU usingJlink Flash commander
  • [Solved] Programming the MCU usingJlink Flash commander
    Im trying to program the Cortex using Jlink Flash commander. I used Jlink commandfile script for programming the device. Im executing the script from batch file. So far everything works fine.
    Now i want to automate this process. I have tried using C# and invoking the batch script from the C# process. The programming is always successful but sometimes the console prints says Target-memory ,unspecified error or JTAG request time out etc.
    My question when i execute batch file manually the console prints proper results but when the same batch file is executed from C# process why the console print shows different results even though program is successful.
    Im using C# because wanted to verify the device functionality which uses GUI and the programming of the device also using C#. This way with single test framework i will be able to program and test.
    Chandan
  • Hi Chandan,
    Thanks for your inquiry.
    Could you please provide us with the SN of the J-Link you are using for this?
    I am not sure if I understand you correctly:
    You are using the J-Link Commander (JLink.exe) to download a file to a target.
    You do this via a .bat-script, which you call from a C# application.
    Is this correct?
    The J-Link Commander is not designed for production purposes. You could either use:
    1) J-Flash which can be called from a batch script or C# directly, or
    2) the J-Link SDK which you could use to integrate the whole process into your C# application.
