[ABANDONED] How to use jlink to program cypress chip CYPD3175
  • [ABANDONED] How to use jlink to program cypress chip CYPD3175
    I can't use the jlink base to flash the cypd3175 chip of cypress. The version of jlink is v10, and the version of jflash on windows is the latest.
    The use of jflash can only perform these operations after the flash is erased. If it has been burned, jlink will not connect anymore. I tried using cypress's miniprog3, and I confirmed that the hardware connection is good There is no problem with the hardware. There is no problem that it cannot be burned once. At the same time, I noticed that there is a toggle power in the cypress programming. I tried to set this on jflash. After trying, I found that after using the target power supply, the returned content of jflash was a little different, but it still failed and could not be connected. .
    Thanks for your inquiry.
    Could you send us a data file to reproduce this issue (e.g. .hex-file)?
