When generating the makefile from a Segger Embedded Studio Projekct on WIndows 10, the makefile breaks when used with GNU Make 3.81 on Windows 10.
The file path for the source files are in the form
The command to make the .ld file has also an issue, the file is not created.
I want to use the makefile as input for the
Happy coding
Christian
D:\Projekte\PT-10\trunk\UiBoard\projects\ble_peripheral\ble_app_pt10_freertos\DefPeri.c
, with \ and without quotes. The makefile works fine when the file path is quoted manually like this "D:\Projekte\PT-10\trunk\UiBoard\projects\ble_peripheral\ble_app_pt10_freertos\DefPeri.c"
"D:/Programme/SEGGER/SEGGER Embedded Studio for ARM 4.30c/bin/mkld" -memory-map-segments "FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x10000" -section-placement-file D:/Projekte/VonArx/PT-10/trunk/UiBoard/projects/ble_peripheral/ble_app_pt10_freertos/pt10ui/s132/ses/flash_placement.xml -check-segment-overflow -symbols __STACKSIZE__=2048;__STACKSIZE_PROCESS__=0;__HEAPSIZE__=1024 -section-placement-macros FLASH_PH_START=0x0;FLASH_PH_SIZE=0x80000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x10000;FLASH_START=0x26000;FLASH_SIZE=0x5a000;RAM_START=0x20002BB8;RAM_SIZE=0xD448 D:/Projekte/VonArx/PT-10/trunk/UiBoard/projects/ble_peripheral/ble_app_pt10_freertos/pt10ui/s132/ses/Output/PP32/Obj/ble_app_pt10_freertos_pt10ui_s132_PP32.ld
CompileDb
tool to get a compile database.Happy coding
Christian
