[ABANDONED] Thread aware debugging broken on FreeRTOS 10.2.1
  • [ABANDONED] Thread aware debugging broken on FreeRTOS 10.2.1
    Hi there,
    It looks like thread aware debugging is broken on FreeRTOS 10.2.1 (not sure if other versions are affected). I'm using Jlink v6.56b (latest).
    Relevant error is:
    Received symbol: pxCurrentTCB (0x00000000)
    ERROR: Mandatory symbol pxCurrentTCB not found.
    pxCurrentTCB is defined and I can set a watch on it.
    Thanks!
  • jeremy.billheimer wrote:
    Relevant error is:
    You prob need to patch a little your FreeRTOS. Depending on your compiler (GCC?)
    Oh btw, which FreeRTOS TAD you using / which IDE? Or you just using Segger's FreeRTOS plugin for GDBServer ?
    There are different thread awareness plugins etc.
    Could you tell us which tool are you using exactly (Ozone, GDB,...)?
