Error while reading netx90 flash
    • Error while reading netx90 flash
      New
      i try to read the netx90 Flash with the J-Flash Tool. First i connect to the target:
      1. Application log started
      2. - J-Flash V6.50b (J-Flash compiled Sep 6 2019 17:58:12)
      3. - JLinkARM.dll V6.50b (DLL compiled Sep 6 2019 17:57:35)
      4. Creating new project ...
      5. - New project created successfully
      6. Connecting ...
      7. - Connecting via USB to J-Link device 0
      8. - J-Link firmware: J-Link Pro V4 compiled Aug 30 2019 09:21:29
      9. - Device "NETX90" selected.
      10. - Target interface speed: 4000 kHz (Fixed)
      11. - VTarget = 3.360V
      12. - TotalIRLen = 8, IRPrint = 0x0011
      13. - JTAG chain detection found 2 devices:
      14. - #0 Id: 0x6BA00477, IRLen: 04, CoreSight JTAG-DP
      15. - #1 Id: 0x10A046AD, IRLen: 04, Unknown device
      16. - Scanning AP map to find all available APs
      17. - AP[4]: Stopped AP scan as end of AP map has been reached
      18. - AP[0]: AHB-AP (IDR: 0x84770001)
      19. - AP[1]: APB-AP (IDR: 0x54770002)
      20. - AP[2]: AHB-AP (IDR: 0x24770011)
      21. - AP[3]: AHB-AP (IDR: 0x24770011)
      22. - Iterating through AP map to find AHB-AP to use
      23. - AP[0]: Skipped. No ROM table (AHB-AP ROM base: 0x00000002)
      24. - AP[1]: Skipped. Not an AHB-AP
      25. - AP[2]: Core found
      26. - AP[2]: AHB-AP ROM base: 0xE00FF000
      27. - CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
      28. - Found Cortex-M4 r0p1, Little endian.
      29. - FPUnit: 6 code (BP) slots and 2 literal slots
      30. - CoreSight components:
      31. - ROMTbl[0] @ E00FF000
      32. - ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB000 SCS
      33. - ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
      34. - ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
      35. - ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
      36. - ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
      37. - ROMTbl[0][6]: E0042000, CID: B105900D, PID: 005BB906 CTI
      38. - Executing init sequence ...
      39. - Initialized successfully
      40. - Target interface speed: 4000 kHz (Fixed)
      41. - J-Link found 2 JTAG devices. Core ID: 0x6BA00477 (None)
      42. - Connected successfully
      After successful connection i tried to read back the Flash via Target --> Manual Programming --> Read Back --> Range
      Then I get an error message:
      Brainfuck Source Code
      1. Reading target memory (0x00100000 - 0x00102000) ...
      2. - Start of preparing flash programming
      3. - ERROR: PC of target system has unexpected value after checking target RAM. (PC = 0xE0A1E09C)!
      4. ---------------------------------------------------------------------- Registers -------------------------------------------------------------------------------------
      5. PC = E0A1E09C
      6. Current: R0 = 000202E0, R1 = 00020300, R2 = 00001000, R3 = 00000007
      7. R4 = 0004656A, R5 = 00106CD4, R6 = 00000000, R7 = 00139907
      8. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------
      9. - ERROR: Failed to prepare for programming.
      10. Failed to execute RAMCode for RAM check!
      11. - End of preparing flash programming
      12. - Start of restoring
      13. - End of restoring
      14. - ERROR: Failed to read back target memory
      15. Disconnecting ...
      16. - Disconnected
      Why I can't read the flash from the netx90? What does this error mean?
      Furthermore I found out from another thread that the APP CPU is currently not supported:
      [SOLVED] Hilscher netx90 APP core dubugging
      Is the APP CPU planned for the future?
      Best Regards
      Johannes
