Focus on Radio button
    • Focus on Radio button
      I'm using Radio with few element (not more then 4).
      If I'm using the font under 16 for element all work fine, I mean that the first element is focused with the rectangle,
      but the font used is more than 16 the first element is never focused with the rectangle.
      In attached the two picture.
      Where I'm wrong ?
      What can I do to have focus with rectangle for font size more then 16 ?
      Thanks a lot for your support
      Best Regards
      Marco Pazzi
    • Hi.
      There is a bug in emWin - if the size of text is greater than size of round radio-button, then the rectangle around the first element of this radio-button will not drawn.
      To avoid this situation increase the size of radio (it is possible only if you use SkinFlex props and it will be applied for all radiobuttons, thus place this code somewhere in your "init" code):
      RADIO_SKINFLEX_PROPS radioProps;
      U8 rbSize = 36;
      RADIO_GetSkinFlexProps(&radioProps, RADIO_SKINFLEX_PI_PRESSED);
      radioProps.ButtonSize = rbSize;
      RADIO_SetSkinFlexProps(&radioProps, RADIO_SKINFLEX_PI_PRESSED);
      RADIO_GetSkinFlexProps(&radioProps, RADIO_SKINFLEX_PI_UNPRESSED);
      RADIO_SetSkinFlexProps(&radioProps, RADIO_SKINFLEX_PI_UNPRESSED);
      Volodymyr.
      The post was edited 1 time, last by volodymyr ().
