Downloading to SM470R1B1M with J-Link Pro
    • Downloading to SM470R1B1M with J-Link Pro
      I am trying to download c code to a SM470R1B1M-HT MCU using IAR Workbench and J-link Pro with a TC2050-IDC cable. When connected the middle LED and LED next to the return arrow are green. When downloading the two LEDs next to the direction arrows blink red. What does this mean and what should I be looking for that would cause this problem?
      After posting this, I found the TC2050-IDC board needed shorting pads to be connected in order for TRST to be sent. However, now I get the same red LEDS along with a "Failed to measure TotalIRLen" error.
      The post was edited 1 time, last by shaddock ().
    • New
      1) Could you send us a J-Link log file? How to enable:
      2) Could you send us a screenshot of the whole Commander output as well?
      3) Do you use custom hardware or an evaluation board? In the latter case which one?
      4) If custom hardware, do you experience the same problem on an evaluation board?
