[SOLVED] Feature Request RTT: SEGGER_RTT_GetAvailWriteSpace
  • [SOLVED] Feature Request RTT: SEGGER_RTT_GetAvailWriteSpace
    Hi!
    We're using RTT to write out a binary packet log file (e.g. like .pcap). To avoid using a special outgoing packet buffer and extra memcpy calls, we first write the packet header and then the packet itself with SEGGER_RTT_Write. If the RTT buffer gets full after writing the header and the RTT mode is set to SEGGER_RTT_MODE_NO_BLOCK_SKIP, the packet can not get written and the log gets corrupted.
    Would it be possible to add a SEGGER_RTT_GetAvailWriteSpace(bufferIndex) or SEGGER_RTT_CanWriteBytes(bufferIndex, numBytes)?
    Here's a draft: github.com/bluekitchen/btstack…639c0a9cb764edb04e3d5e483
    I'm aware that this would only works without multi-threading or when using RTT from ISRs.
    Thanks for consideration
    Matthias
  • Hello Matthias,
    Thank you for your feedback.
    We discussed this internally and will add a API call that returns number of free space in the buffer.
    This should be available with the next J-Link release.
    But keep in mind that the buffer will be free in most cases after the callback _GetAvailWriteSpace has been executed in SEGGER_RTT_WRITE due to the speed of J-Link and asynchronous nature of RTT as the callback will only return the current buffer state while in the background J-Link continues grabbing the data.
    Another way would be to use RTT in TRIM mode and use the return value from SEGGER_RTT_Write(). Then try to resend the difference of requested bytes and written bytes again.
  • Thanks, that's Awesome!
    Yes, I think I'm aware of the limitations and the async nature. To me, it looks like RTT TRIM + retry is similar to NO_SKIP_BLOCK, if the retry happens right after the write (if there's another queue, the retry could happen later, but then, a larger RTT buffer could be used ).
    Matthias
