emwin - GUI_LANG_LoadCSVEx loading different CSV files
    • emwin - GUI_LANG_LoadCSVEx loading different CSV files
      As noted in the emwin manual, when calling GUI_LANG_LoadCSVEx it deletes the old resources and loads the new one.
      The scenario in my code is:
      1. Load CSV1 -> read values
      2. Load CSV2 -> read values
      3. Load CSV3 -> read values
      So far no issues, works perfectly.
      4. Load CSV1 again -> Fails (GUI_LANG_LoadCSVEx return 0).
      Note: if I reload CSV2 or CSV3 Again, it does not fail.
      Also if I load CSV1 twice in a raw (only for debug), it fails
      2. Load CSV1 again -> Failes.
      Note: CSV1 size is 60K. But I believe that emwin does not load the CSV to the RAM, it only loads the specific text to RAM when calling GUI_LANG_GetTextBufferedEx function.
      How can I spot the cause of this issue or is it a known issue for big CSV files. ?(
    • Hi Sysmop226,
      I've tried to reproduce your error, but it worked fine for me. And yes, file size shouldn't matter with GUI_LANG_LoadCSVEx() as this function only gets size and file offset of the text locations.
      Have you checked if the file handle you pass to GUI_LANG_LoadCSVEx() is still valid?
      Florian
    • Hi Florian,
      Thanks for the reply.
      I can reproduce the issue only with big CSV files.
      1. // Set access to CSV file
      2. int test1 = GUI_LANG_LoadCSVEx(_GetData, (void *)_acLanguageParam_V1);
      3. int test2 = GUI_LANG_LoadCSVEx(_GetData, (void *)_acLanguageParam_V1);
      in test1 I get the number of languages in the file.
      in test2 I get 0 -> Failure.
      The CSV file (Array) is Valid, its a const array located on the External Flash:
      1. __root const unsigned char _acLanguageParam_V1[56700UL + 1] @ 0x90081000
      As I mentioned earlier, when applying the same scenario with a smaller CSV (20K) for example, it works fine.
    • Hi Sysmop226,
      I have tried to reproduce this with an array like you said, with an even bigger file and less target memory than the file size, but it still worked fine. Even with an older version (5.48) from before something in the GUI_LANG module was changed, everything worked fine.
      Can you tell me which emWin version you are using?
      Florian
      This is the version.
      1. #define GUI_VERSION 54401
      I'm afraid I cannot send the application and the CSV files.
      But I started to suspect that the library does not clean the resources.
      Test scenario 1: I have a big CSV file (60k) when trying to load it twice it fails on the second one.
      Test scenario 2: I have another CSV file (20k) I load it 4 times, the fourth fails :!: .
      I can attach the conf files.
      Please find attached.
      • Config.7z
        (6.9 kB, downloaded 40 times, last: )
      I couldn't reproduce the error with this version either. Based on how your test went, it sounds like a memory issue. But in my test, emWin didn't run out of memory.
      You could still check if you run out of memory by watching the variable "GUI_ALLOC__Context", there's an element called "NumFreeBytes". If you do, that's your error, emWin needs more memory.
      If that still didn't solve it, I'm afraid I can't help you out any further, unless you send me a sample that I can run to reproduce your error.
      Florian
      How could it be a memory issue? your manual says that the emwin releases the resources when loading a new CSV/Text file.
      Is there a way to release the resources manually?
      See the following numbers:
      Num of free bytes before calling the Load function is: 199,252
      Num of free bytes after calling the load Function for the first time: 59,844 :!: :!: :!:
      Of course there will be no space for extra load if the load function does not release the resource!
      My GUI_NUMBYTES is 256K
      1. #define GUI_NUMBYTES (250) * 1024
      Senario for GUI bytes:
      1. int freeBytes1 = GUI_ALLOC_GetNumFreeBytes();
      3. int freeBytes2 = GUI_ALLOC_GetNumFreeBytes();
      4. int test2 = GUI_LANG_LoadCSVEx(_GetData, (void *)_acLanguageParam_V1);
      5. int freeBytes3 = GUI_ALLOC_GetNumFreeBytes();
      6. int test3 = GUI_LANG_LoadCSVEx(_GetData, (void *)_acLanguageParam_V1);
      freeeBytes1 = 199,252
      test1 = 6
      freeBytes2 = 59,844
      test2 = 0
      freeBytes3 = 118,972
      test3 -> Hardfault :!: --> GUI_ALLOC_Free Failed
      All the scenarios that I have ran leads for one conclusion: the library does not free resources as it says in the manual.
    • Hi there,
      I've tried again with what you said, but I couldn't reproduce such a behavior regarding the memory. Before my first call of GUI_LANG_LoadCSVEx(), there are 253,020 free bytes, after the first call it's 214,024 bytes. And no matter how often I call GUI_LANG_LoadCSVEx() with the same array pointer as parameter, the number of free bytes stays the same.
      There is a function to free the memory, but it got added with emWin V5.50. By the way, when you're already using an emWin library by a vendor like ST, you get a discount of up to 50% when you purchase the emWin source upgrade (more info here: segger.com/products/user-inter…win/emwin-source-upgrade/).
      Florian
