[SOLVED] Impossible to have multiple instances of SES on MacOSx Catalina
  • [SOLVED] Impossible to have multiple instances of SES on MacOSx Catalina
    Good morning everyone,
    I have been happily using SES for a few years now to work on Nordic devices (NRF52). So far I worked in a Linux environment, and I used to open a few projects at the same time to copy code fragments or to compare source codes in case of problems.
    I recently switched an a MAC running OSx Catalina, and I am not able to open more than a single project....whenever I have an open project, if I try to open a new one, the latter is opened in the existing windows so there is no way for me to have 2 (or more) projects side by side.
    I already tried activating the proper option in the SES options (Tools-->Options-->Environment--> Allow Multiple SEGGER....), as suggested in other threads (or as I did in Linux), but this does not seem to have any effect. I tried to put the option both to YES or NO (to check if there was maybe a mistake there), but still I can open only a single project.
    This is pretty annoying especially when I have to check for project settings, included files, source code and so on, so it would be great if someone can suggest me a possible solution to this issue.
    These are the details of the SES version I am running
    SEGGER Embedded Studio for ARM
    Release 4.30a Build 2019110506.40491
    macOS x64
    Thanks for the help!
    Lorenzo
  • Hello Lorenzo,
    The reported behaviour was reproducible and we are working on a fix.
    The issue comes from new access rights management imposed by Catalina which has not been communicated properly by Apple.
    Anyhow we are sure that we will find a solution soon.
    For now a quick workaround would be to use different versions of ES at the same time. This does not seem to be blocked by the new macOS access right system.
    To stay up to date with ES releases you can subscribe here:
    segger.com/notification/subscribe.php?prodid=196
    quick update.
    Try launching ES with CL option "open -n".
    This should allow you to open multiple instances of the same app under macOS.
    Edit: An example for this can be found in our Wiki:
    wiki.segger.com/Start_multiple…Studio_instances_on_macOS
