RTOS plugin when no GDBServer used ( = IDE / tool uses jlink dll )
    • RTOS plugin when no GDBServer used ( = IDE / tool uses jlink dll )
      Any way to get the RTOS awareness plugin when your IDE/ tool is _not_ using GDBserver but talks to J-Link using shared library? As for e.g. Ozone (as I understand it uses jlink dll/*.so ).
      The post was edited 1 time, last by v01d ().
    • New
      The IDE and Ozone use different awareness plug ins than GDBServer.
      ES: wiki.segger.com/Enable_RTOS_Awareness_in_Embedded_Studio
      Ozone: Shipped with Ozone. Can be found in Ozone installation folder under Plugins. How to use them is explained in Ozone manual.
    • New
      If I understand you correctly you are looking to port the RTOS awarness to other IDEs/debuggers? Is that correct?
      In that case the interfacing with the J-Link library is generic and only a read and write function is called. Everything else is handled in the IDE/debugger itself, like getting symbol information and calculating offsets.
      For Embedded Studio and Ozone we can use identical plugins. They are .js files and can be found in e.g. the Ozone install directory.
      The .so approach is the "old" one for Ozone and is kept for backwards compatibility. The new one is using the .js files.
      The API for this is explained in the Ozone user manual.
      The GDB Server plugin is not compatible to Ozone or ES as the GDB Server has to use another approach due to the limitations of the GDB Protocol.
      So you can only use the available plugins from us in third party IDEs if the IDE uses the same API which I doubt. For third party IDEs most likely other plugins must be created which is usually out of our reach. We recommend using SEGGER software tools when debugging for compatibility.
    • New
      Hi Nino,
      If the tool in question already uses J-Link, and by my understanding, likely the jlink *.so/*.dll , because I don't see it invoking GDBServer, and because the traces do not look like GDBServer ones, is there then any immediate 'hook' to the Segger's RTOS plugins?
      (The specific tool I'm wondering about at this moment is TI's CCS. They do integrate Segger's J-Link support )
