[CLOSED] J link 5V supply not turning on , with command power on perm
  • [CLOSED] J link 5V supply not turning on , with command power on perm
    I am using J link for flashing TLE9879 controller , i have given feed back from 5V pin to Vref pin .
    When i used "power on perm" command , 5V pin still is showing ground and same is reflected in Jlink command
    As VTref=0.000V , when i reopened j link command application .
    Could you provide us with a photo of the two pins you connected?
