Jflash - Error connecting to ATSAML11E15A after programming
    • Jflash - Error connecting to ATSAML11E15A after programming
      Hello.
      I am having a problem reconnecting to ATSAML11E15A after programming using JFlash. We are using JFlash in a factory tool to program 2 different micros. I am using JFlash V6.54 and a JLink Plus Compact. I have been able to successfully connect to and program the L11 but I get an error after disconnecting and re-connecting. I can no longer communicate with the chip. I have to erase the chip using ATMEL-ICE and then I am able to connect again. A have no issues when programming with the ATMEL-ICE but we can't use it in our factory tool architecture to program both micros.
      - J-Link firmware: J-Link V10 compiled Oct 22 2019 16:28:15
      - Device "ATSAML11E15A" selected.
      - Target interface speed: 4000 kHz (Fixed)
      - VTarget = 3.340V
      - InitTarget()
      - Cold-Plugging detected
      - InitTarget()
      - ERROR: InitTarget(): PCode returned with error code -1
      - ERROR: Failed to connect.
      Could not establish a connection to target.
      Programming and verifying target (27268 bytes, 3 ranges) ...
      - Connecting ...
      - ERROR: Could not program and verify target, not connected
      Darlene
    • Hello Darlene,
      Is this reproducible on an evalboard?
      If so, on which?
      Could you provide us with a .hex file to reproduce this issue?
