JLink GDB Server version 6.54 introduces error code "9" and terminates
    • JLink GDB Server version 6.54 introduces error code "9" and terminates
      I use the JLink GDB Server to perform debugging from Jetbrains CLion. Up until version 6.54, this worked fine :
      1. /Applications/SEGGER/JLink_V652e/JLinkGDBServerCLExe -device STM32F411VE -endian little -if SWD -select usb=778137274 -ir -localhostonly 1 -port 2331 -speed 2000 -vd -nosilent -swoport 2332 -telnetport 2333 -halt
      2. SEGGER J-Link GDB Server V6.52e Command Line Version
      3. JLinkARM.dll V6.52e (DLL compiled Oct 16 2019 12:33:11)
      4. Command line: -device STM32F411VE -endian little -if SWD -select usb=778137274 -ir -localhostonly 1 -port 2331 -speed 2000 -vd -nosilent -swoport 2332 -telnetport 2333 -halt
      5. -----GDB Server start settings-----
      6. GDBInit file: none
      7. GDB Server Listening port: 2331
      8. SWO raw output listening port: 2332
      9. Terminal I/O port: 2333
      10. Accept remote connection: localhost only
      11. Generate logfile: off
      12. Verify download: on
      13. Init regs on start: on
      14. Silent mode: off
      15. Single run mode: off
      16. Target connection timeout: 0 ms
      17. ------J-Link related settings------
      18. J-Link Host interface: USB
      19. J-Link script: none
      20. J-Link settings file: none
      21. ------Target related settings------
      22. Target device: STM32F411VE
      23. Target interface: SWD
      24. Target interface speed: 2000kHz
      25. Target endian: little
      26. Connecting to J-Link...
      27. Error during pretty printers setup: Undefined info command: "pretty-printer". Try "help info".
      28. Some features and performance optimizations will not be available.
      29. J-Link is connected.
      30. Firmware: J-Link STLink V2 compiled Jun 26 2017 10:34:41
      31. Hardware: V1.00
      32. S/N: 778137274
      33. Checking target voltage...
      34. Target voltage: 3.30 V
      35. Listening on TCP/IP port 2331
      36. Connecting to target...Connected to target
      37. Waiting for GDB connection...Connected to 127.0.0.1
      As you can see it complains about "pretty-printer" but ignores this and proceeds to the connection.
      With version 6.54, I cannot connect any more :
      1. /Applications/SEGGER/JLink_V654/JLinkGDBServerCLExe -device STM32F411VE -endian little -if SWD -select usb=778137274 -ir -localhostonly 1 -port 2331 -speed 2000 -vd -nosilent -swoport 2332 -telnetport 2333 -halt
      2. SEGGER J-Link GDB Server V6.54 Command Line Version
      3. GDB Server stopped, exit code 9
      4. Error during pretty printers setup: Undefined info command: "pretty-printer". Try "help info".
      5. Some features and performance optimizations will not be available.
      6. Process finished with exit code 0
      The error code "9" is not listed in the manual, so I cannot tell what has happened. Does anyone know what is going on?
      Ewout Boks
    • Hi Ewout,
      These both are no log entries that come from J-Link GDB Server.
      We have neither an exit code 9, nor do we have any code in our application that could produce these strings.
      Could you make sure that you do not have any other GDB Server running?
      Where do these log entries come from?
