[SOLVED] JLinkScript return value of customized action function
  • [SOLVED] JLinkScript return value of customized action function
    Question about the return value of a customized action function in a JLinkScript file.
    In my script I have the "int SetupTarget(void)" function which is called when I run the following command:
    JLink.exe -CommanderScript <CommandScriptFilename> -JLinkScriptFile <JLinkScriptFilename>
    In my JLinkScript I want to return an error in case of a failure but no matter what code (-1, 1, -1000, 1000) I return in the SetupTarget() function I don't see any difference in the output.
    The following thread forum.segger.com/index.php/Thr…cript-file-documentation/ describes the same issue.
    Is it correct that the return code of the SetupTarget(void) function is ignored?
    We were able to reproduce the behaviour and are working on a fix. The return value for SetupTarget is indeed not being evaluated at the moment.
    Sorry for any inconvenience caused.
  • Hi Joe,
    quick update.
    The latest J-Link software version should have fixed return values for SetupTarget.
