[SOLVED] Failed to measure CPU clock frequency
  • [SOLVED] Failed to measure CPU clock frequency
    Dear,
    I've recently had a problem using ozone with PLC2387 and LPC 2148. Previously everything worked fine. But now I received following error message from Ozone
    Device "LPC2387" selected.
    TotalIRLen = 4, IRPrint = 0x01
    JTAG chain detection found 1 devices:
    #0 Id: 0x4F1F0F0F, IRLen: 04, ARM7TDMI-S Core
    Connected to target device.
    Elf.GetEntryPointPC(); // returns 0x8000
    Target.SetReg ("PC", 0x8000);
    Read memory error @ address 0x40000000, 16 bytes: Communication timeout.
    Failed to halt CPU for clock frequency detection!
    Target voltage too low (1 Volt is required, Measured: 0.0 Volt).
    Download failed: J-Link reports an unspecified download error
    Connection to target device lost.
    Disconnected from target device.
    Target.SetReg ("PC", 0x8000): Not connected.
    The problem for device LMP2148 is equal. I can download program to flash using JFlash. But if I use J-Link, I will receive equal error message.
    I use Ozone 2.70a (x64), SEGGER J-Link Commander V6.54 (Compiled Oct 28 2019 10:35:28) and SEGGER J-Link ARM V10.10 with firmware 22 Oct 2019. But, I periodically received following message in J-Link
    Connecting to J-Link via USB...Updating firmware: J-Link V10 compiled Oct 22 2019 16:28:15
    Replacing firmware: J-Link V10 compiled Jun 3 2015 BTL
    Waiting for new firmware to boot
    FAILED: Communication timed out: Requested 4 bytes, received 0 bytes !
    Could not read J-Link capabilities.
    Cannot connect to J-Link
    J-Link>con
    J-Link connection not established yet but required for command.
    And J-Link is unavailable until rebooted. Help me, please
    BR,
    Andy
    The post was edited 2 times, last by afedotov77 ().
  • Hello Andy,
    The last days were very busy.
    Did the Problem appear when you updated Ozone or did it work with the Ozone version you are currently using before?
    Could you check if the voltage really drops below 1V?
    Best Regards,
  • Hello Fabian,
    When problem appeared first time I didn't updated Ozone. I updated Ozone later, I hoped to fix problem. But I could not fix problem.
    I checked voltage between VCC and GND on JTAG in during download .hex file - voltage was stable and equal 3.3 V.
    BR,
    Andy
  • Hello Andy,
    Could you tell me what is different to the last time it worked with these chips?
    Did you update the J-Link Software and Documentation Pack?
  • Fabian, I don't see any difference environment (debugger, scheme, chips and software SEGGER for debugger) between last successful experience and bad experience (when appeared problem). I updated J-Link software up to latest version, but it had fixed problem. Also, I tested my J-link PLUS with new PC with latest Ozone and J-Link software - result is equal (problem saved). I don't know, that I can do it.
    I'm embarrassed by the error message Replacing firmware: J-Link V10 compiled Jun 3 2015 BTL. Early (when Ozone and J-Link PLUS worked) this message didn't appeared.
    BR,
    Andy
  • Hi Andy,
    Could you please answer the following questions?:
    1) Does this replacing firmware error also appear when you are using J-Link Commander (jlink.exe)?
    2) Could you send us a picture of the whole Commander output?
    3) Is the J-Link connected to the PC directly, or via an USB-Hub?
    4) Could you send us a picture of your debug setup?
    Fabian Federschmidt
  • Fabian, answers is below
    Message about replacing firmware does not always appears and Yes, this message also appear when I using J-Link Commander.
    Picture is in attachement
    Firmware: J-Link V10 compiled Oct 22 2019 16:28:15
    Hardware version: V10.10
    S/N: 600112975
    VTref=3.303V
    J-Link>con
    Please specify device / core. <Default>: LPC2387
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    TIF>
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>500
    Connecting to target via JTAG
    ARM7 identified.
    ETM V1.2: 1 pairs addr.comp, 0 data comp, 4 MM decs, 1 counters
    J-Link>r
    Reset delay: 0 ms
    Reset type NORMAL: Using RESET pin, halting CPU after Reset
    J-Link>loadfile c:\WORKS\EM133_12.9.28.24_24D1_test.hex
    Downloading file [c:\WORKS\EM133_12.9.28.24_24D1_test.hex]...
    ****** Error: Failed to measure CPU clock frequency
    Communication timed out: Requested 4 bytes, received 0 bytes !Read memory error @ address 0x40000000, 16 bytes: Communication timeout.
    Unspecified error -1
    I tried both variants - connect j-link to PC directly and via USB-Hub. Results are equal - problem has saved.
    My debug setup from Ozone is in file "debug setup.pdf".
    • debug setup.pdf
      (202.46 kB, downloaded 682 times, last: )
    Please note that this is no support forum so replies from our engineers may be delayed.
    For more information see my signature.
    Regarding your J-Link, it appears that this one is defective. I have created a ticket with our sales department and they will answer you via e-mail shortly.
    To avoid communication over multiple channels this thread will be closed now.
