[SOLVED] Missing "Connect to running target" option?
  • [SOLVED] Missing "Connect to running target" option?
    Update: If I create a NEW debug configuration from Segger (not STM), I see the "connect to target" option.
    However, even though I explicitly filled in the path C:\Program Files (x86)\SEGGER\JLink\JLinkGDBServerCL.exe,
    I get an error "Error while launching command: gdb --version" when I try to debug.
    The project and ELF settings all look correct, and match the working non-Segger STM debug configuration.
    Any ideas???
    Original post: I'm using J-Link base to debug an STM32F413CG over SWD, in the STM STCubeIDE Eclipse package.
    Debugging generally works great, thanks, but...
    Configuring the debug profile, I can't find a "Connect to running target" option as explained here:
    mcuoneclipse.com/2015/03/20/at…r-j-link-gdb-and-eclipse/
    How do I connect to a running target?
    Thanks!
    Best Regards, Dave
    PS: I'm using JLink_Windows_V652e
    Also, no change after I updated to the latest GNU ARM C/C++ J-Link Debugging 4.1.4.201704251808 ilg.gnuarmeclipse.debug.gdbjtag.jlink.feature.group Liviu Ionescu
    The post was edited 1 time, last by DaveN ().
    We are not aware of any issues with the attach functionality of our J-Link probe.
    All our other debug tools can attach to the target without any issues (Ozone, Embedded Studio, ...).
    Please understand that the Eclipse Plugin is not our software so its not maintained or supported by us.
    If you run into troubles with setting that tool up we recommend getting in contact with the support channel of the tool provider.
  • Hello Dave,
    Please find the Wiki article here:
    wiki.segger.com/STM32CubeIDE
