[SOLVED] j-link edu mini (V6.52e) - CPU could not be halted
  • [SOLVED] j-link edu mini (V6.52e) - CPU could not be halted
    I wonder what would be a reason for stopping the communication with the target MCU after 4-5 sec.
    I use Keil uVision 5.28.
    The log below contains the relevant information.
    Running with Code Size Limit: 32K
    Device "STM32L031K6" selected.
    JLink info:
    DLL: V6.52e, compiled Oct 16 2019 12:16:54
    Firmware: J-Link EDU Mini V1 compiled Oct 8 2019 14:59:05
    Hardware: V1.00
    S/N : 801000133
    Feature(s) : GDB, FlashBP
    * JLink Info: Found SW-DP with ID 0x0BC11477
    * JLink Info: STM32 (connect): Can not attach to CPU. Trying connect under reset.
    * JLink Info: Scanning AP map to find all available APs
    * JLink Info: AP[1]: Stopped AP scan as end of AP map has been reached
    * JLink Info: AP[0]: AHB-AP (IDR: 0x04770031)
    * JLink Info: Iterating through AP map to find AHB-AP to use
    * JLink Info: AP[0]: Core found
    * JLink Info: AP[0]: AHB-AP ROM base: 0xF0000000
    * JLink Info: CPUID register: 0x410CC601. Implementer code: 0x41 (ARM)
    * JLink Info: Found Cortex-M0 r0p1, Little endian.
    * JLink Info: FPUnit: 4 code (BP) slots and 0 literal slots
    * JLink Info: CoreSight components:
    * JLink Info: ROMTbl[0] @ F0000000
    * JLink Info: ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C0 ROM Table
    * JLink Info: ROMTbl[1] @ E00FF000
    * JLink Info: ROMTbl[1][0]: E000E000, CID: B105E00D, PID: 000BB008 SCS
    * JLink Info: ROMTbl[1][1]: E0001000, CID: B105E00D, PID: 000BB00A DWT
    * JLink Info: ROMTbl[1][2]: E0002000, CID: B105E00D, PID: 000BB00B FPB
    ROMTableAddr = 0xF0000000
    * JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    * JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
    Target info:
    Device: STM32L031K6Ux
    VTarget = 1.794V
    State of Pins: TCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 255
    Hardware-Breakpoints: 4
    Software-Breakpoints: 8192
    Watchpoints: 2
    JTAG speed: 500 kHz
    Load "STM32L031-SMARTAG1\\STM32L031-SMARTAG1.axf"
    Include "C:\\Users\\abg015\\Desktop\\STM32L031-SMARTAG1\\MDK-ARM\\Dbg_RAM.ini"
    * Name: Dbg_RAM.ini
    * Purpose: RAM Debug Initialization File
    * Note(s):
    * This file is part of the uVision/ARM development tools.
    * This software may only be used under the terms of a valid, current,
    * end user licence from KEIL for a compatible version of KEIL software
    * development tools. Nothing else gives you the right to use this software.
    * This software is supplied "AS IS" without warranties of any kind.
    * Copyright (c) 2008-2011 Keil - An ARM Company. All rights reserved.
    Setup() configure PC & SP for RAM Debug
    FUNC void Setup (void) {
    SP = _RDWORD(0x20000000); // Setup Stack Pointer
    PC = _RDWORD(0x20000004); // Setup Program Counter
    _WDWORD(0xE000ED08, 0x20000000); // Setup Vector Table Offset Register
    FUNC void OnResetExec (void) { // executes upon software RESET
    Setup(); // Setup for Running
    load %L incremental
    g, main
    WS 1, `debug1,0x10
    WS 1, `value,0x0A
    **JLink Warning: CPU could not be halted
    ***JLink Error: Can not read register 15 (R15) while CPU is running
    ***JLink Error: Can not read register 16 (XPSR) while CPU is running
    ***JLink Error: Could not read memory location 0x20001750 when trying to clear soft RAM BP
    Could not start CPU core. (ErrorCode: -1)
    ***JLink Error: Can not read register 0 (R0) while CPU is running
    ***JLink Error: Can not read register 1 (R1) while CPU is running
    ***JLink Error: Can not read register 2 (R2) while CPU is running
    ***JLink Error: Can not read register 3 (R3) while CPU is running
    ***JLink Error: Can not read register 4 (R4) while CPU is running
    ***JLink Error: Can not read register 5 (R5) while CPU is running
    ***JLink Error: Can not read register 6 (R6) while CPU is running
    ***JLink Error: Can not read register 7 (R7) while CPU is running
    ***JLink Error: Can not read register 8 (R8) while CPU is running
    ***JLink Error: Can not read register 9 (R9) while CPU is running
    ***JLink Error: Can not read register 10 (R10) while CPU is running
    ***JLink Error: Can not read register 11 (R11) while CPU is running
    ***JLink Error: Can not read register 12 (R12) while CPU is running
    ***JLink Error: Can not read register 13 (R13) while CPU is running
    ***JLink Error: Can not read register 14 (R14) while CPU is running
    ***JLink Error: Can not read register 17 (MSP) while CPU is running
    ***JLink Error: Can not read register 18 (PSP) while CPU is running
    ***JLink Error: Can not read register 20 (CFBP) while CPU is running
    Could you verify your setup with J-Link Commander?
    Does a connection work here?
    Could you provide a screenshot of the J-Link Commander session?
    Is the target voltage of 1.8 V expected?
    Thank you for your comments.
    It's genuine ST STEVAL-SMARTAG1 powered by CR2032, and the 1.8V was expected.
    I tested the connectivity on ST-LINK as well and got similar results.
    That's why I investigated the CR2032 and found that some of them dropped the voltage for short amount of time during turning on the LED.
    So I replaced them with quality ones have have no problems since then.
    Thanks again for your involvement.
    Bogdan
  • Hello Bogdan,
    Great to hear that you are up und running again.
