[SOLVED] How to make Flash Placement file.
  • [SOLVED] How to make Flash Placement file.
    I am a hardware engineer and not very familiar with software or firmware other than the very basics.
    I am trying to move a project from the Keil IDE to SES. I am working with Nordic's NRF52832 for this project. This project complies, flashes, and works in Keil but I can't get it to work in SES. I tried following Nordic's guide for this but was unable to get it to work and I have also asked for help on Nordic's dev zone.
    I am getting errors when compiling with the linker and I do not understand how to make a Flash Placement file.
    The errors I am getting are in the attached image.
    How do I make one or generate one.
    I am sorry for my inexperience, what can I do to solve this.
    Thank you
    How to create flash placement files and their syntax is explained in the Embedded Studio manual. You can open the manual under Help->Contents or browse it online.
    studio.segger.com/
    Here are the corresponding sections covering that topic:
    studio.segger.com/ide_section_placement.htm
    studio.segger.com/arm_memory_map_files.htm
    studio.segger.com/ide_section_placement_file_format.htm
    Alternatively you can use the SEGGER Linker. The manual for it can be found in the Embedded Studio install folder under /html/SEGGER.
    Example implementations for the xmls can be found as explained in the manual or in the Nordic SDK.
