Delete old bitmap,display new bitmap
    • Delete old bitmap,display new bitmap
      I want to delete the previous bitmap and show the new bitmap.
      I used the callback function, but I couldn't.
      How can I do it.
      my code not work.
      static void _cbDialog(WM_MESSAGE * pMsg)
      switch (pMsg->MsgId) {
      case WM_PAINT:
      GUI_DrawBitmap(&bitmap,x, y);
      break;
      void Callback(WM_MESSAGE * pMsg);
      WM_HWIN hItem;
      case WM_PAINT:
      GUI_DrawBitmap(&newbitmap,x, y);
      break;
      default:
      WM_DefaultProc(pMsg);
      break;
    • Hi Hakan,
      you can use more than one callback for the same window, however it is not advisable in your case when there are very little differences between them.
      It would be best to just use one callback and decide in the WM_PAINT case which bitmap should be shown. This could be done with e.g. a guard, when a button is pressed, as shown below:
      2. *
      3. * _cbBk
      4. */
      5. static void _cbBk(WM_MESSAGE * pMsg) {
      6. switch (pMsg->MsgId) {
      7. case WM_PAINT:
      8. GUI_SetBkColor(GUI_BLACK);
      9. GUI_Clear();
      10. if (ButtonPressed) {
      11. GUI_DrawBitmap(&Bitmap1, 0, 0);
      12. } else {
      13. GUI_DrawBitmap(&Bitmap2, 0, 0);
      14. }
      15. break;
      16. default:
      17. WM_DefaultProc(pMsg);
      18. break;
      19. }
      20. }
      21. /*********************************************************************
      22. *
      23. * Public code
      24. *
      25. **********************************************************************
      26. */
      27. /*********************************************************************
      28. *
      29. * MainTask
      30. */
      31. void MainTask(void) {
      32. GUI_Init();
      33. WM_SetCallback(WM_HBKWIN, _cbBk);
      34. while (1) {
      35. GUI_Delay(100);
      36. }
      37. }
      Remember to redraw your window in order to show the new bitmap (WM_InvalidateWindow()).
      Also note that every callback needs a default case that calls WM_DefaultProc(pMsg) for normal windows and <WIDGET>_Callback(pMsg) for widgets.
      Florian
