[SOLVED] Profiling CortexM0 with Ozone
  • [SOLVED] Profiling CortexM0 with Ozone
    Is "Code Profiling" with Ozone possible when the target is a ARM CortexM0 (which lacks SWV/SWO, and if I understand correctly, the ITM module)?
    Ozone happily opens the "Code Profile" window for me, but no execution statistics seem to be collected.
    Cortex-M0 devices unfortunately lack any kind of hardware tracing capability. That is why nothing happens in Ozone.
    Optional trace features are implemented in Cortex-M0+ and higher.
    Nonetheless we provide SEGGER RTT as an I/O terminal that can be used for advanced debugging techniques and code analysis.
    segger.com/products/debug-prob…about-real-time-transfer/
    Our free tool SystemView utilizes that RTT buffer and enables software tracing even on Cortex-M0 that way:
    segger.com/products/development-tools/systemview/
    So maybe that would be an option for you?
    thanks for confirming this.
    I looked into SystemView and RTT. If I understand correctly, I can get coarse-grained function execution times recorded with it, but only if I manually instrument the source code of the functions to monitor?
    While reading up on all this, I bumped into the Data Watchpoint Trigger (DWT) module which is an optional but implemented feature, (since I am on a STM32F0). But this thread Enable PC-Sampling in Ozone suggest Ozone is not (yet) able to profile using the DWT PC sampling register?
    thank you for your input,
    kalle
  • Hello Kalle,
    Correct.
    Ozone currently does not offer PC sampling as a trace method. However our IDE Embedded Studio can be used for that purpose:
    segger.com/products/development-tools/embedded-studio/
