Ozone 2.70a: Issues running under Ubuntu 18.04 in virtual machine
    • Ozone 2.70a: Issues running under Ubuntu 18.04 in virtual machine
      New
      Spent (too) much time today getting Ozone running on Ubuntu 18.04 running inside a VMware 14 virtual machine. Just to mention, I have no issues debugging and running the same HW setup (i.MX6 Solo custom board with J-Link HW 9.4) with pure GDB, and exactly the same initializations, under this VM. After spending a few hours on this today, I decided to move the Ozon project to the Windows 10 host, which worked straight away without any issues.
      What I see is after loading up the project, then running the download and reset sequence, things look ok, default memory view shows sane values and read out correct, but after it is not possible to read memory, and not possible to start the cpu. See attached log. Neither reading register memory space, nor DDR3 space works. Trying to run simply returns 'Could not start CPU core. (ErrorCode: -1)'. If memory serves me correctly it was indeed possible to read CPU registers.
      Any idea what could be going on? or are there some known issues?
    • New
      Ozone should behave always the same no matter the platform.
      Could you provide an example project for reproduction? Then we could take a look.
