[ABANDONED] Ozone 2.70a: Issues running under Ubuntu 18.04 in virtual machine
  • [ABANDONED] Ozone 2.70a: Issues running under Ubuntu 18.04 in virtual machine
    Spent (too) much time today getting Ozone running on Ubuntu 18.04 running inside a VMware 14 virtual machine. Just to mention, I have no issues debugging and running the same HW setup (i.MX6 Solo custom board with J-Link HW 9.4) with pure GDB, and exactly the same initializations, under this VM. After spending a few hours on this today, I decided to move the Ozon project to the Windows 10 host, which worked straight away without any issues.
    What I see is after loading up the project, then running the download and reset sequence, things look ok, default memory view shows sane values and read out correct, but after it is not possible to read memory, and not possible to start the cpu. See attached log. Neither reading register memory space, nor DDR3 space works. Trying to run simply returns 'Could not start CPU core. (ErrorCode: -1)'. If memory serves me correctly it was indeed possible to read CPU registers.
    Any idea what could be going on? or are there some known issues?
    Ozone should behave always the same no matter the platform.
    Could you provide an example project for reproduction? Then we could take a look.
  • Thanks for your reply. Adding the two project files here. The one titled Ozone3.jdebug is used on the Win10 host, the other on the Ubuntu VM. The target in both cases is physically the same custom i.MX6S board with 1GB of RAM, and the same JLink.
    • Ozone-Ubuntu.jdebug
      (21.19 kB, downloaded 456 times, last: )
    • ozone3.jdebug
      (21.71 kB, downloaded 376 times, last: )
