J-Link Debugging the R5 core on the Xilinx Ultrascale+ XCZU7EV7
    • J-Link Debugging the R5 core on the Xilinx Ultrascale+ XCZU7EV7
      New
      I am attempting to do a debug session on the arm R5_0 core of an Ultrascale+ XCZU7EV7 using a Jlink Plus and, so far, have had no luck getting it to work.
      My setup:
      • Xilinx ZCU104 Ulrascale+ evaluation board
        • SW6 is set to Jtag mode (on, on, on, on)
      • J-Link plus running Firmware version V10.10
        • Connected to the ZCU104 via flywires to a 14pin adapter connected to J180
      • Ozone debugger, or Eclipse GDB SEGGER J-Link Debugging
      Whenever I start a debug session I it seems to get as far as writing the app to memory before the failures start to happen. Ozone will loose connection while writing to memory, and Eclipse complains about memory read failures but doesn't disconnect and ends up deep in the weeds.
      I've attached the debug logs from both Ozone and Eclipse and any information as to how to resolve this problem would be greatly appreciated.
      Note:
      Debugging the ZCU104 works as expected with the Xilinx SDK and the Xilinx debug cable, but we are trying to move our project away from being locked to the Xilinx SDK and use CMAKE instead.
      Thank you
      -Matt
